Interest thread, 2-Piece front rotors and rear rotor options
#47
extended the coupon on more week, after that it is it.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#49
__________________
#50
Have to go home and check my brakes tonight. Don't know if I can make it another month waiting on the rears. My rear pads are pretty toast, constantly squealing, and I would really prefer to seat the new pads and rotors at same time rather than seat the new pads to old rotors and then new rotors a month later.
#51
Tech Info Resource
#53
Just got my front rotors on and love them! I have one question. Is there any oversized pad options for the front from another application that will fit our brembo 6 pot upfront? I am thinking 3mm wider would take up all of the surface area on the braking surface.
Mike
Mike
#54
PICS Please!!!
#57
Mike
__________________
#58
pic of rotors post bed in. Using these with the Carbotech XP8 pads and its truly amazing. You run out of tire pretty quick so it will be interesting to see what happens with the r-comps at the track. Also the XP8 pads are slightly undersized relative to the backing plate, so they fit these undersized rings perfect. I need to talk to them about the compound to back plate ratio and see what can be done.
__________________
#60
The rings on my vehicle are still the 5mm smaller sized rings. All shipping rings are the stock sized rings.
__________________
