Slammed F!
I could not agree with you more.
lowering slightly with coils or springs looks fine but droping it to the ground looks just plain stupid. I really don't understand why people seem to think that "slamming" a car is so cool looking. 1) it is a major decrease in performance 2) it probably rides like it looks, like it's on the axel.![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
To each it's own
Thanks bro. I've seen many 2IS's slammed but rarely seen a F this low. I might be the only one
Nope but I've been pulled over twice in the last 6 months for random check up cuz it has a Alberta License plate. I just recently moved back to BC last summer. They just hassle me for that but other then that no problems. Cops usually follow me ring up my plate to check if car is stolen then they turn off and leave me alone.
low is where its at..and in the snow too
![](http://i88.photobucket.com/albums/k195/Figbline720/isf/IMGP7815-1-1.jpg)
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
Some say it handles better, but if you have ever been drivng at the limit and any part of your suspension hits the Bump-Stop, it will throw your vehicle so far off the line that one may not recover, especially if the line is near the edge of the road.
From Urschlag Motorsports:
So what happens when a lowered car runs out of bump travel and contacts the bump stops?
Very rough ride characteristics. With the reduced suspension bump travel, even small bumps will use up all of the available travel. We've all seen cars driving around (typically manufactured in Japan) that are lowered to the point that every imperfection in the pavement upsets the entire chassis. This is a result of little to no bump travel.
Extreme steady-state understeer or oversteer. Under hard cornering conditions, the chassis rolls on the suspension. The outside suspension compresses, and the inside suspension rebounds. A frequent problem is that the chassis roll causes the front or rear suspension to run out of travel and contact the bump stops. If this happens in the front suspension, a severe mid corner understeer problem will occur. If the rear suspension bottoms, a severe mid corner oversteer will be the result. This is a real problem with a lot of BMWs that I've seen, typically in the front suspension causing understeer.
Instability during abrupt direction changes. A pretty common problem typically seen in autocrosses. The car handles fine through steady state corners, but either oversteers or understeers through quick transitions. This problem can have many causes, one is lack of bump travel combined with soft shocks and struts. The car will corner in one direction and the chassis will roll from the cornering forces. When the driver quickly changes direction, the chassis will roll in the opposite direction and receive a 'boost' from the inside springs that are still compressed. This will in some cases temporarily put the outside suspension on the bumpstops. This effect can really wreak havoc through a slalom!
This is a variation on number two. The car will roll on the suspension during hard cornering, but not quite to the point of contacting the bump stops. Then the slightest bump will use up the remaining bump travel and induce sudden and extreme understeer or oversteer. This type of oversteer can be particularly dangerous! Another symptom of this is a car that is very unsettled driving over FIA curbing at the track.
Hey isf-88 fire me an IM if you would be interested in a dyno day/BBQ in Kelowna this summer. I'm planning one with the GF's old man and a couple of his buddies. Should have some interesting cars there, and quite the spread.
