Belt slip noise in manual mode shifting >5.5k rpm?
Old 05-09-14, 10:09 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
^^ Sounds like the tensioner... While your at it put a new belt it..
~ Joe Z
Old 05-09-14, 11:46 PM
I8ABMR
I8ABMR's Avatar
I have seen sooo many F video with the cars accelerating and making the belt slip noise. At least we know its very common. I am going to have them replace the belt and the tensioner pulley at next service.
Old 05-10-14, 04:59 AM
dannyk8232
dannyk8232's Avatar
any tips on persuading the local dealer to replace these for free/under warranty? do u guys think requesting a tech ride shotgun while I demonstrate will get me anywhere?
Old 05-10-14, 02:42 PM
I8ABMR
I8ABMR's Avatar
Thats exactly what Im going to do. Im not going to tell the dude to take it out and launch it over and over again. . When I call to schedule Im going to tell SA I want the tech to take a ride. Worse case the tech could stand on the side of the road as you pass and shift. Its obvious its a belt. There was a TSIB for this on the earlier car but on the later cars its still happening. Luckily its minor and cheap to repair.
Old 05-11-14, 03:12 AM
dannyk8232
dannyk8232's Avatar
I could've sworn I had checked before, but today I verified over and over again that the noise ONLY occurs with the a/c on..when it's on, it sounds sublime until about 4000 rpm when I hear the whirring noise winding up more and more the higher the revs. with a/c off, no abnormal noise whatsoever.
is this because the tension is off with the belt attached to the a/c? too tight-pulley shape compromises-weird noise? I'm by no means experienced with this kinda thing.
also, how would u guys play this with regards to the third-party extended warranty? (or does anyone know a good shop in Ventura county?)
thanks in advance....
Dan
Old 05-11-14, 07:33 AM
Joe Z
Joe Z's Avatar
For the simple Belt Slip noise.. Replace the belt...
Should be part of a normal maintenance over a period of time.
As the belt ages it becomes drier & harder.. Eventually it also cracks on the inner veins.
I put a new one after 4 years.. @ 60k miles
~ Joe Z
Old 05-11-14, 05:22 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,065 Likes on 2,462 Posts
I also recently replaced the belt and tensioner with OEM Lexus parts. The mystery noises I had disappeared.
It's not hard, and it's not a lot of money. It is (as Joe said) also routine maintenance.
Old 05-11-14, 05:31 PM
dannyk8232
dannyk8232's Avatar
Cool, thanks Joe and Lance. I just checked the LSB from back in 08 for replacing this...looks like it won't be under extended warranty but is a pretty simple job
Old 05-11-14, 06:04 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Takes about 30 minutes start to finish as long as the engine is cool when you start. The hardest part is threading the new belt - Pro tip - start with the alternator pulley on the left and finish with the A/C compressor, and you'll want a 1/2" drive breaker bar at least 18" long to hold the tensioner in position while you thread the belt.
Old 05-11-14, 08:15 PM
dannyk8232
dannyk8232's Avatar
You, my friend, are a straight-up gangsta! Much appreciated...
Old 05-11-14, 10:08 PM
I8ABMR
I8ABMR's Avatar
Dan
Mine happens with or without and now I've noticed I can get a little slip if the car is launched even in just sport.
Old 05-12-14, 11:44 AM
todd4566
todd4566's Avatar
Hmm.. I've noticed that supercharger whine sound before and didn't think much of it until now. Guess I better look into a new belt and tensioner.
Old 05-13-14, 07:38 AM
VtotheJ
VtotheJ's Avatar
What are the part numbers for all parts needed for this?
Old 05-13-14, 06:22 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
16620-0W131 - Tensioner - $165.30 from Sewell
90916-02632 - Belt - $35.92 from Sewell
Rock Auto has the same tensioner (DAYCO Part # 89380) for $100 less than Lexus. Same manufacturer, looks like same part. I didn't try it, but if you're on a budget, it's probably a good option.
Old 05-13-14, 07:23 PM
VtotheJ
VtotheJ's Avatar
Thanks Lance.
Quick Reply: Belt slip noise in manual mode shifting >5.5k rpm?
