In the market for an ISF intake...Recommendations?
I have been reading/browsing through different aftermarket intakes: Here's what I have found available..let me know your thoughts/experiences! Thanks!
Joe Z intake tube + drop in filter
K & N true intake w/ cone
Tanabe (utilizes factory box?)
*Swift Racing Technologies intake (w/ air fuel computer)
Injen intake (seems too cheap/generic to be worth it)
or do i stay with the stock intake?
OH, and BTW, i do have the Joe Z exhaust installed thus far...
Many here have gone with the Joe Z intake/exhaust combo. K & N uses their own filter, so it would require taking apart the factory filter box. Takeda from what I've seen utilizes the stock box partially. And Injen's intake isn't cheap at all. Good brand name, and their numbers are accurate. It's up to you which one you want to use. My choices would be either the Joe Z or Injen if you want some extra power and a nice looking intake for your F. How are you liking the exhaust so far?
I have yet to find an intake with sustainable gains over the stock set up so far doing my research on this subject. Although I do want increased throttle response from a larger filter as well as the sound, I don't want to sacrifice HP. I'm starting to consider the Joe-Z intake tube combined with a different filter to fit in the stock airbox.
Could you give me a run down of your impressions of it Lou?
Love my Injen intake.... It is not in any way cheap, defiantly quality part & it fits perfect. I did not do before and after dynos but it sounds great, im getting 25 mpg on the highway and I don't think I have lost power. Throttle response in top end is noticeably better.
I'm trying to decide on an intake right now as well. From the intake shoot out thread, the Takeda produced lower HP than stock and injen. Having said that though, the OP put a lot more miles on his Takeda before he fitted the injen intake on there which he put 10 miles on the car before he dyno'd it and then put the stock intake on there with virtually no miles driven and it dyno'd higher than the other 2 stock intakes.
Lou
Before the Takeda I had a JoeZ with as K&N drop-in. My preference for the Takeda is purely personal. I like the look and the sound. The Takeda feels almost totally like the stock filter, maybe a bit more up top. I installed a friend's Injen a couple of weeks after I put mine on. IMO, the quality was not as good as my Takeda. The install was easier and the filter element is a little bigger, but it's far more exposed to hot underhood air. Again, I'm happy with my choice![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Lou
Lou
^^ Elite said in Splats NA build that their prototype intake didn't make gains till it had headers, exhaust, ported tb & intake manifold behind it, then it pulled 14 wheel and 10ft lbs over stock air box/joe z pipe and filter. I know there are not a ton of people with those mods who have hit dynos and post but it may be that the after market intakes make a bigger difference once the car has the ability to suck more air...The stock intake is sufficient for the stock car.
http://www.lexusfforum.com/forums/showthread.php?t=3038 check it out
