Service or Repair Manual Source
I did a quick search and couldn't see any recommendations - so what sources are you guys using for the service manual or repair manual so you have the actual torque specs when doing suspension upgrades, brake jobs etc. After life with an E39 M5, I feel you shouldn't be eyeballing or thinking "tight enough" on these things.
So any online providers that you recommend specific for the IS-F. Thanks.
The Maker
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
The Maker
__________________
sweet man look way easier now that i seen wut it looks like thanks man... im guessin the rear is the same way huh... that should take me about half day sayin everything goes good not just gotta get the parts damn it...lol
The Maker
The rear is similar, but you have in internal drum brake (parking brake). Sometimes it will require removing tension on to release the rotor hat off. This is done through removing the small rubber plug to expose the hole and lining it up with the access hole in the hub, bottom dead center. Then you take a small flat head and roll the tensioning wheel forward or back dependong on which adjustment you are making it tighter or looser. I will do the rears once I need to replace them as well.
__________________
Tech Info Resource
Should take about 2 hours from jacking up the car. I've done it in less.
