Rotors
What and where are you guys getting your rotors from? Im just curious how much they are? aftermarket and OEM.
I have about 14,000 miles and need pads now. But i dont plan on changing the rotors, just a pad swap out. All this talk about you need to change the rotors with the pads is B.S., you can still drive the car without new rotors,lolz. People are so techinical, your not going to crash and burn if you dont change the rotors
i got centric rotors from tirerack.. i have a wholsale account there so they were dirt cheap.. now the oem rotors are afordable too..
on most cars you can just replace the pads and reuse the rotors , the is-f has a very agresive compound pad and by the time the pads wear out the rotor is below the minimum thickness so i would recomend that you replace them.. but thats you call..
