I finished the stealth look I was after with a set of JoeZ CF exhaust tips. Though I'm not too sure how stealthy the cars is as I have been pulled over twice in the last 4 weeks for speeding. Knock on wood I received warnings both times but I think my numbers up so it's time to slow down a bit.
i was reading about plasti-dip spray for the windows
I believe someone has done it on here
probably works well
im considering it if the gloss matches the current look
probably works well
I advise against plastidip. I plastidipped the front kidney grills of my 335 and just removed it all yesterday after 7 coats it was still peeling away. I would recommend (if you want to go the cheap route) Black enamel paint from home depot, small paint roller and LOTS of painters tape. Should work well and if it ever gets chipped, paint right back over it.
