Painted engine cover
Old 03-21-11, 11:58 AM
silky f
silky f's Avatar
Default Painted engine cover
Looking inside the engine compartment with everything being so dark turns me off with seeing a silver engine cover. I decided to experiment with my painter on painting the cover...it's definitely my taste, could be yours or maybe not. It's painted glass black and a redish color. It's a tad bit dirty @ the moment. Positives/Negatives feedbacks are highly appreicated.
Attached Thumbnails Painted engine cover-img_0034.jpg   Painted engine cover-img_0035.jpg   Painted engine cover-img_0036.jpg
Old 03-21-11, 12:08 PM
MiiK350
MiiK350's Avatar
Black joez intake with red emblem would look great with that cover.
Old 03-21-11, 12:11 PM
silky f
silky f's Avatar
that is actually what i was going for.
Old 03-21-11, 02:40 PM
bnizzle87
bnizzle87's Avatar
Looks great! The red F is a nice touch. I've been thinking about adding some color under the hood just for fun, just haven't found the time.
Old 03-21-11, 04:15 PM
darbs242
darbs242's Avatar
Heres mine...My theme is Black and CF on silver so i figured i would keep the motor cover simple
Old 03-21-11, 05:11 PM
Weapon F
Weapon F's Avatar
here are my engine cover pics
The hard part was sanding everything down and smoothing it out and getting that nice reflective shine.
Old 03-21-11, 05:21 PM
darbs242
darbs242's Avatar
^^^ Your time paid off, its looks super shinny!! I like the blue you picked
Old 03-21-11, 05:36 PM
Weapon F
Weapon F's Avatar
Thanks darbs I color matched paint
Old 03-21-11, 06:20 PM
7No
7No's Avatar
Sick, man. Me want!
Old 03-22-11, 06:40 AM
IS350atWOT
IS350atWOT's Avatar
I'd like to paint mine. These look hot!! What kind of paint should I use? Anything special?
Old 03-22-11, 07:16 AM
kraven9
kraven9's Avatar
Maybe it's the picture but I'm not feeling the red, the others that posted look good though.
Old 03-22-11, 09:00 AM
darbs242
darbs242's Avatar
I used high temp flat black... Not sure if the high temp was necessary but I didn't want flaking
Old 03-22-11, 10:56 AM
mugenh22a4
mugenh22a4's Avatar
That looks much better than the red.
Old 03-22-11, 02:04 PM
Fitment Factory
Fitment Factory's Avatar
Looks great guys!!!
Old 03-22-11, 03:22 PM
Weapon F
Weapon F's Avatar
Use a quality high heat spray paint I prefer VHT products, next use acetone or presole to clean and degrease the area you want to paint, next mask off the area's you don't want paint to get on using blue painters tape. Your first two coats should be light then you can apply heaveir coats of paint and your done. Cost $20 to $25.
Now if you want smooth finish like my engine cover this much more labor intensive. First you have to sand area down, once thats done you need to apply several thin coats of body filler and I mean thin coats sand them down. Then prime that area using high build primmer wet sand fix any imperfections prime again and wet sand. Then using high heat paint applying several thin coats then building them up once dry apply high heat clear just for some extra shine and protection and your done. Cost $50 to $75 depending on type of paint and clear used. I used automotive paint on my cover and VHT high heat clear waited a few days then wet sand clear and buffed out using 3M medium cut rubbing compound, sealer then wax. My total cost was $100 due to extra steps I took.
here are some pics of steps
Quick Reply: Painted engine cover
