lexus is f 2011 puddle light replace
Old 03-24-11, 09:21 AM
tonyph33r
tonyph33r's Avatar
Default lexus is f 2011 puddle light replace
is there a way to pull out lamp it seen 2011 is different.
Old 03-24-11, 10:16 AM
ACEtheOG
ACEtheOG's Avatar
the procedure is the same for 2011.
carefully pull out mirror FROM THE BOTTOM - it snaps on and off. snapping it back in can be tricky. if you break the tabs your screwed. i believe replacement mirrors for the f are 3-500 buckeroos per side.
remove 4 screws holding the side mirror assembly together.
carefully pry apart the side mirror assembly.
you now have full access to the puddle lights!
tip. if you are replacing the incandecent lights with leds, make sure the led is not too long... its a tight fit in there.
Surovich
RX - 3rd Gen (2010-2015)
22
05-24-17 05:59 AM
Mbdj
Hybrid Technology
07-16-15 11:24 AM
LeighRX450
12-29-13 10:25 AM
redog
09-08-11 11:37 AM
chaos2orde
08-21-11 12:17 PM
Quick Reply: lexus is f 2011 puddle light replace
