PPE Headers
Old 11-04-12, 03:59 PM
  #286
zojirushi
zojirushi's Avatar
Originally Posted by TheHighLow
i only have 2k miles on the ride. How long and difficult is the install.
I remember that on my old 4.2L S4 with auto tranny downpipe install was like 6 hours.
Any recommended installers in NJ? I've read that someone went to AFterFX in Stamford, CT (which is 45 minutes away from me), however a closer place for maintenance purposes would be better.
A few tri-state owners have gone to Bulldog Motorsports in Clifton NJ with good results.
http://www.bulldogmotorsportsllc.com/
Old 11-13-12, 05:13 PM
  #287
zapa
zapa's Avatar
I think we figured out what was causing my codes. On the o2 sensor wire extenders part of it was rubbing the header so when it would get hot it melted straight through
Old 11-13-12, 06:12 PM
  #288
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,973 Likes on 2,403 Posts
That's very bad for the ECM.
Old 11-13-12, 06:13 PM
  #289
zapa
zapa's Avatar
I know but i am hoping that i have not harmed anything else..
How would I know if I have messed up anything else??
Old 11-13-12, 07:27 PM
  #290
ISFPOWER
ISFPOWER's Avatar
that would def do it, had that problem with a previous car.
Old 11-14-12, 02:17 PM
  #291
Weapon F
Weapon F's Avatar
Hey HighLow I had my PPE installed at AfterFX in CT great shop they nothing but highend work and I mean highend Lambos, Bentley GT, Porsche, Ferrari,McClarrens etc that being said they are not cheap but the work is impeccable. I also now have connection with Lexus of Larchmont, NY Ray Catena, I spoke to service Manager he use to work at Lexus of Greenwich but now work for Lexus of Larchmont and at that location they will install headers with no problem. I know head mechanic Walter and he does great work very knowledgeable guy into cars and is the only one that works on my F when I bring it to dealer. So if you want I can bring you to either shop let me know we can meet and I'll introduce you to them.
Old 11-14-12, 02:31 PM
  #292
zapa
zapa's Avatar
Well I just got all of the codes again... What could it be
Could I have damaged the ECM??
Old 11-14-12, 02:41 PM
  #293
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Fried power circuit for the O2 sensor heater in the ECM.
Old 11-14-12, 02:49 PM
  #294
zapa
zapa's Avatar
Would that mean I need a whole new ECM
Old 11-14-12, 03:24 PM
  #295
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Yes unless you know someone who will fix the burned out regulator in the ECM.
You should check the voltages before you do anything though. The heater circuit has specific voltages associated with it when it is operating. If it's not applying power to the heater circuit, the ECM will set a DTC and the sensor will not work at all.
Old 11-14-12, 03:28 PM
  #296
PPEHeaders
Sponsor
PPEHeaders's Avatar
The ECU is pretty well protected internally against shorts like this. There is a fuse that controls the heater circuits which I am sure has blown. I am not sure on its location, but I would definitely check and replace next.
Old 11-14-12, 03:43 PM
  #297
lobuxracer
Tech Info Resource
lobuxracer's Avatar
EFI 2 fuse is for the heater circuits on the secondary sensors. But there would be other issues, and it would not even start without a DTC if EFI 2 was dead. The main A/F also has a separate fuse.
I've seen the regulators die in other Toyota products. It's part of why I have a stack of Supra ECMs in my garage.
Old 11-14-12, 03:54 PM
  #298
zapa
zapa's Avatar
I dont know who to believe here. I respect both of their opinions. Once again my codes I got today were P0136, P0139 P0156 P0158. Some of which were pending.
Old 02-02-15, 08:02 PM
  #299
LexISguy
LexISguy's Avatar
Three years later and still enjoying the headers. Beside the exhaust any possible other goodies in the works?
Old 06-03-15, 10:36 PM
  #300
MileHIFcar
MileHIFcar's Avatar
Bump from the grave.......... did you ever find out what was causing the codes you got?? Was it what Lance had said or PPE? You never followed up with the solution?
Dble Agent
IS F (2008-2014)
07-09-18 09:21 PM
2izoom
RC F (2015-present)
03-30-17 06:13 AM
deathstar
03-09-12 02:48 AM
Hypebeast
Performance
08-22-11 09:23 AM
lukeisf
IS F (2008-2014)
04-02-11 09:42 AM
Quick Reply: PPE Headers
