Exhaust Manifold Choices
Lou
Tech Info Resource
Wow. The PPE headers are significantly better according to those two dynos. Torque is flatter and higher from 2.5k to 5k, and just plain better for a street driven car. Nice work PPE!
Good results
Yep, I think I can - But it is just My Opinion - JE uses, IMHO, a very optimistic dynamometer, a Dynapak. In the PPE thread I have included runs from my runs with a DynoJet and Caymandive's also run on a dynojet. He had Sikky headers, a JoeZ exhaust and no cats. His best run was 385.8 HP and mine was 382.0 HP. I have PPE headers, a Fabricated dual exhaust utilizing stock mufflers and Magnaflow cats. So, Camandive and I dynod on the same brand of dyno, on a day with a similar temperature. My exhaust is a little more restrictive than his (stock mufflers vs JoeZ and Cats vs no cats). The decision is yours![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Lou
Lou
Hey Lou, do you remember when I had my high flow cats added to my setup that I didn't lose nor gain any power (link here)? To be honest I believe your exhaust setup is right on par with mine power wise. Your results also verify my belief that the stock mufflers flow pretty darn well and keep the noise to a minimum without causing too much of a power loss. In this case it's about 4-5hp tops. I don't believe we will ever be able to verify who makes the best power producing header. None of them are equal length and they all remove the primary cats hence producing similar gains. The decision for people will come down to price, quality and how they want to go about the O2 simulation be it pipe extensions with the PPE's or an electronic device such as with the SIKKY headers where you are guaranteed not to have any CEL come on. Just my .02 and Lou, very nice job on the work done so far.
Now I have to wonder how many people are going to go out and get some stock mufflers to fabricate onto their loud aftermarket exhaust system.
We are learning new things all the time with this car in regards to exhaust.
I definitely wouldnt test both sets on the same car. What i said would be needed is to have both cars on the same dyno on the same day. With numbers this close, i believe its the only way to choose a concrete winner. I was actually surprised to see that the products were so close in performance results. Its good for us lurking in the background waiting to whip out the credit card.
Lou
Lou
I do find it hard to believe that if I were to throw a Joe z on or ISS forged I would only gain 10whp to match with the other 2 dynos here. If that's the case than the oem mufflers are not bad at all.
![](http://img215.imageshack.us/img215/1425/scan0001cw.jpg)
Any new video of your new setup? I'd love to hear it!
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Lou
http://www.youtube.com/watch?v=PVPxWgn-NpA
Considering Im running the most restrictive exhaust with a header set up I would say these numbers are very real and Im also using a dynojet and the temps are very close as well.
How much louder is it inside with just the headers? Do the secondary cats do a good enough job at removing the toxic exhaust smell?
I wonder how much more power you'd get with the Borla axle back minus the crushed stock Y.
I'm planning to pull the trigger on headers and get either the Borla axleback or have a custom axle back made so I can retain the 2ndary cats.
Thanks,
Tom
^^^^Hey Tom
That's certainly an option I hadn't thought about. You should listen to the Borla, it is, IMHO, quite loud. As far as the secondary cats working, I have seen and heard the PPE Prototype Car which did have the complete stock system exhaust, and it did not smell or exhibit any signs that I could see that the secondary cats were not working.
Lou
Lou
^^^^Hey Tom
Lou
Lou
Thanks for the info!
I guess I can get headers first, see how loud they are and then decide on the axle back.
Tom
I have the cats removed all (4) and I do get the smell if standing outside in the back of the car. The added sound is pure sex nothing too loud at all. Just get headers first then the exhaust. I just paid for my ISS forged exhaust today, but I plan on adding resonators if its too loud.
AdamLexus
Performance & Maintenance
12
01-26-08 09:19 AM
