ISF Slower in hot weather - heat soak?
Old 04-19-11, 10:33 AM
UCrazyKid
UCrazyKid's Avatar
It's an air density/oxygen capacity issue much more than it is a motor temperature issue. For the same reason cars loose power at high altitude even when the air is cool.
this is the same reasons that dynos compensate for ambient air temp and altitude when calculating HP.
Air Density Calculations:
To begin to understand the calculation of air density, consider the ideal gas law:
(1) P*V = n*R*T
where: P = pressure
V = volume
n = number of moles
R = gas constant
T = temperature
Density is simply the number of molecules of the ideal gas in a certain volume, in this case a molar volume, which may be mathematically expressed as:
(2) D = n / V
where: D = density
n = number of molecules
V = volume
Then, by combining the previous two equations, the expression for the density becomes:
(3)
where: D = density, kg/m3
P = pressure, Pascals ( multiply mb by 100 to get Pascals)
R = gas constant , J/(kg*degK) = 287.05 for dry air
T = temperature, deg K = deg C + 273.15
As an example, using the ISA standard sea level conditions of P = 101325 Pa and T = 15 deg C, the air density at sea level, may be calculated as:
D = (101325) / (287.05 * (15 + 273.15)) = 1.2250 kg/m3
Old 04-19-11, 11:33 AM
Lets Drive
Lets Drive's Avatar
Strange. I didn't notice a significant drop in power when I ran my track weekend at CMP in 102F heat. Oil temps went to one bar short of the top, but power didn't seem to suffer any more than I would expect from running in genuinely hot weather.
Speaking of which, do you know what the individual bars correspond to in temperature?
Normal driving yields three bars, and I've done four with more spirited driving, but not sure how they translate.
Old 04-19-11, 12:47 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,988 Likes on 2,413 Posts
See this post.
ISFSCOTT
IS F (2008-2014)
22
11-07-16 12:38 PM
RSXiMUS
IS F (2008-2014)
20
09-29-14 12:00 PM
MouthOfWar
IS F (2008-2014)
07-26-13 08:54 PM
CK9887
IS F (2008-2014)
09-04-12 06:38 PM
Quick Reply: ISF Slower in hot weather - heat soak?
