Spring Mtn Drive and FS Concave Wheel shots. 305 Rear
Well it was frantic but I managed to wake up early this morning and worked a little last night over a full moon to install the wheels for a test drive. I will probably have to pull them off tomorrow as we have been know to get a nice 2 ft storm aroung this time of year. Had a good crew to stretch out on some nice snow free canyon roads. Stopped in Central City for a few shots.
Car drives great with the 255/305 setup. No budging the rear in corners however for as low as I am I will probably have to increase spring rates or jack it back up a bit. Bottoming rubbing on hard cornering, but I really had to push it. This is also partially due to the added weight and perhaps the 10K springs cannot keep up with this setup and this ride height.
Finished things off in a overlook of downtown and the windy sky.
A note about the wheels/tires:
-I ended going with Nitto Invo due to availability and reasonable cost. Still waiting to fit a Conti EC DW in the same sizes.
-255/35/R19 Front 305/30R19 Rear.
-Front is a 19x9, rear is a 19x11
-Front diameter is 26" rear is 26.3"
-I have one rim barrel that was damaged in shipment, so I have another barrel on order so I can balance the right rear.
- The fronts right now are flat face but they can make a concave face with these offests and I may even order them for these wheels.
-Current offsets are very conservative to fit a STOCK car with no rolling at all. I am working on the next round which will be 10mm more agressive in back and 20mm more up front and will require fender work.
-Car has my MEGA arms and extended toe links installed and -2.1 camber last I aligned.
PM me if interested in this set or a custom order.
Currently things are 3 month LT.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Tech Info Resource
How much lower are you from standard ride height?
Have you done roll center - roll couple calculations?
I made this one myself, details in other threads.
Offsets- keep in mind I have 10K invested and 6 months in the measurements I have taken and the offsets. Also my based on rim barrel profiles and tire fitments, all offsets are not created equal. I am not willing to post offsets at this time as this is part of the full service I want to provide. i.e. you tell me what fitment you want, I plug it into my specs and create the offsets for fitment, tires (by brand) that will get you what you want.
These are a 19x11 rear and I have two offset versions that for two manufacturers that I have test. By taking control of the wheel manufacturing, the tire mounting and having the vehicle to test fit prior to delivery to a customer, I feel like I have the best way of applying my parameters to fitments.
My MEGA arms are a complete rear LCA replacement with spherical bearings, camber adjustment and sway link mount adjustment.
My Toe links are on the other side of the Knuckle and balance the rear LCA. This allows me to run more negative camber and not suffer as much toe in on compression (bump steer)
Thanks Lou, yes these offsets are designed for people with a lease or other situation where they would rather not touch the fenders. I got to thinking right before I was going to shave mine that I should really figure this out for people as there are a lot of these cars on lease. Shaving this fender lip is also not straight forward as the seam is smack in the middle.
__________________
For those that do not realize, the rear end influences steering quite a bit and the balance of the toe link with the LCA can set under/oversteer in hard cornering. This is dynamic and is not just a matter of aligning it on an alignment rack. Its the balance as the two links travel together. The key here is that I have added adjustment which allows the tuning of this balance.
__________________
A few more shots today. Working on a little edit.
__________________
