IS-F wheel spacers thread.
Hey guys - just looking to get some opinions of wheel spacer options out there for our cars.
Can those who have them note the spacers they used and their experience with them?
I want to run 15mm Spacers all around, and I only plan to lower the front end with H-techs. I will likely only upgrade my tire sizes from 235's front and 265's rear. What should my side wall size be in those sizes? remain with 40 / 35 per stock or go to 35/30?
I am looking at these spacers: http://www.protuninglab.com/ic-v2515-0054.html
just wondering if there is anything I need to do to make them fit or if they are straight bolt on?
Thanks guys,
Thanks guys,
Tech Info Resource
Thanks guys,
Thanks guys,
I personally would not run spacers unless I was using them to correct an improper offset, but I'm not driving a fashion statement either.
Yikes, from the cracking to someone replacing a wheel bearing....maybe I might just steer clear from spacers.
Thanks for that post - greatly appreciate it.
If I were to get spacers, sounds like H&R is the way to go - however I wouldnt want to mess with changing OEM studs for longer ones.....so this option is out too I guess.
im running the 15 mm h&r's all around on teins and am very happy with the look. i do rub just a touch at full lock reverse with stock tires (passneger front fender), so i dont think i could go any wider when i buy tires next time.
^^^ I think your front wheels are on the wrong sides....
Joe Z
P.S. - I have never run spacers on any car I have owned or operated...
Joe Z
Thanks again.
I had to run 5mm spacers in the rear because I bought my wheels second hand from an IS350 owner. The rear offsets weren't enough to clear our calipers. Other than that, yeah, if the car was meant to have a wider stance, Lexus would have designed it that way.
