Tire has a rip in it?!
So I went to clean the brake dust off my tires this weekend...first I took it off with a soft cloth then polished it off using Armor All Multi-purpose Auto Cleaner...worked pretty decently.
I noticed my front right tire has a slight tear... almost like a very small layer of the tire has a rip. It is a slight tear, but hasn't affected the tire pressure.
Towards the top left of the tire you can see it:
![](http://i1100.photobucket.com/albums/g409/remiks3/IMG_20110514_162526.jpg)
Here's a closeup:
![](http://i1100.photobucket.com/albums/g409/remiks3/IMG_20110514_162512.jpg)
Is this anything to be concerned about? My tire pressure is unaffected.
Here's a closeup:
same thing happened to me on my is350 except the rip was vertical going towards the tread. nothing happened for a couple of weeks then one day I came to a flat tire. I would get it replaced ASAP if I were you; you don't want your tire going out while your driving
Looks like the sidewall was pinched when you curbed your wheel. I could have just cosmetically damaged the rubber and not damaged the structural sidewall. If it starts to bulge out or bubble, get it replaced quick. Depending on the mileage of the tires you will probably have to replace 2 (Left and Right).
It is not possible to repair damaged sidewalls, only punctures to the tread.
you should have both tires on the same axle replaced. it is completely unnecessary to replace all 4 at the same time. side wall is usually the weakest and subjected to the most stress during driving. it may be cometic damage, but none of us can tell you how deep the damage is based on that picture alone. when a side wall fails, it can be catastrophic and without warning. i would have tires replaced ASAP.
I don't know if it's because of the angle of the picture... but your rim looks slightly bent. Did you happen to hit a pothole very hard? The gash on the sidewall/rim look like damage from the edge of a pothole, not curb rash.
