What tire pressure are you running?
Old 05-18-11, 01:11 PM
UCrazyKid
UCrazyKid's Avatar
Default What tire pressure are you running?
I got my car back today from the dealer and the paper work says they adjusted the tire pressure to 34 front and 38 rear. This seems wrong as the manual, door sticker and previous service reports all list 36psi all around.
What is going on? Technician error?
Old 05-18-11, 01:22 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
36 x 4 should be fine on the stock set up... And your right, it's on the door..!
I run 36 & 38 on my non stock set up..
Joe Z
Old 05-18-11, 04:39 PM
D2M
D2M's Avatar
40F 38R for me, bridgestone RE050
Old 05-18-11, 06:57 PM
seimsag
seimsag's Avatar
Default tire pressure
I run 40 all the way around.
Old 05-18-11, 09:12 PM
ShadowISF
ShadowISF's Avatar
After I got aftermarket tires, I run 40 all round.
Old 05-18-11, 10:01 PM
Supraman16
Supraman16's Avatar
40 all around. The dealer just adjusted mine to 33 in the front and 35 rear and the car feels weird...harder to turn. Most dealer techs are clueless.
Old 05-19-11, 03:05 PM
UCrazyKid
UCrazyKid's Avatar
The Verdict: Technician error (duh)
correct pressure 36psi.
I have now set all tires to 38psi cold. Max for my tire is 51psi.
Old 05-19-11, 10:14 PM
Dv8tion388
Dv8tion388's Avatar
35x4
~Dv8
Old 05-20-11, 12:06 AM
GiantsFan
GiantsFan's Avatar
For those of you with PS2s... what do you guys run?
Door says high 30s but tire rack says max PSI for the pS2 is 50??
Right now I have 36 all around.
Old 05-20-11, 10:04 AM
Joe Z
Joe Z's Avatar
^^ If you want your tires to wear normally..
Any where between 35 and 38 will be fine.
Joe Z
Old 05-20-11, 12:58 PM
digger08
digger08's Avatar
50 PSI is a max load rating - not the actual PSI.
Old 05-20-11, 06:22 PM
GiantsFan
GiantsFan's Avatar
Originally Posted by Joe Z
^^ If you want your tires to wire normally..
Joe Z
Thanks Looks like im good then
Old 11-30-11, 03:53 PM
ERDoc74
ERDoc74's Avatar
Has anybody else noticed in the manual that if you live in a country with speed limits above 100mph, that they reccomend to add an additional 9 psi. (ie. 45 psi)??? If I ROUTINELY drive over 100mph for long periods of time, is this what I should be inflating my tires too??
Old 11-30-11, 07:10 PM
avgj0F
avgj0F's Avatar
...and the rest of the clicking engine noise story?
Old 12-01-11, 04:02 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,997 Likes on 2,421 Posts
Cold pressure at the track is 32 psi on all four. Normal driving is recommended 36 psi after playing with it up and down a bit. Stock works best for street duty.
Quick Reply: What tire pressure are you running?
