Wheel pitting on 08 ISF (with solution!)
Old 06-20-11, 10:45 AM
flipside909
Lexus Connoisseur
flipside909's Avatar
Originally Posted by ES3
Has anyone been given consistent instructions on how to prevent this? Wax wheels? It's abnormal. Even if Lexus would replace any wheels, it's going to happen again, no?
If the wheels are washed thoroughly with soap or specific ph balanced wheel cleaner and water (non acidic wheel cleaners), you should never have an issue. I'm pretty thorough with cleaning my factory wheels (even cleaning the inner wheel barrel) because I hate the look of the brake dust being caked onto the wheel face and crevices.
I have about 36k miles on my 09 IS F. There have been times I let the brake dust sit on the wheels longer than a month due to the periods of rain we had here in SoCal....and i have not had any issues with wheel pitting. The only wheel damage I have are small knicks from stones and road debris which is expected of any kind of wheel.
Old 06-23-11, 01:21 PM
splitfire
splitfire's Avatar
May be only 08 model have this problem?? I just talk to a customer of my that work at the dealership he look at another ISF that went in exect same problem as mine!!!!!! I think BBS Japan made a bad batch of wheels and only few of us have this wheel pitting issue not everyone else. It could be BBS's paint supplier's problem.. I don't know how some of you guys got it replace under warrenty and not everyone with this issue???
Old 06-23-11, 03:23 PM
crazymikie
crazymikie's Avatar
I was able to use clay bar to get a lot of the pitting off my wheels, however, the areas where the spokes meet the rim are ruined. The paint is just gone.
Next time I'm in for an oil change, I'll ask the dealer to check it out. I'm not going to get my hopes up.
Old 06-25-12, 07:03 PM
Jb2009
Jb2009's Avatar
Default Found an awesome fix!!!!!
Buy some CarPro Iron X Paste and the normal iron x spray. The paste is the more effective product though. Ph neutral and safe for wheels and paint. The stuff reacts with embedded ferrous particles. Take a look at the attached before and after photos. I tried to pick the best 5. I tried everything, and was about to get the wheels refinished until I found this. I had numerous people tell me they couldn't do anything for them. The gel dwells on the surface, and after multiple passes I was able to get rid of all off it. 1 tube of the paste will do all four rims and 1 can of spray. Get a pair of gloves, and a small brush and go to town! I keep up with the wheels now with Sonax full effect wheel cleaner, EZ wheel brush, and Armour-all wheel protectant spray after each wash.
Attached Thumbnails Wheel pitting on 08 ISF (with solution!)-img_0698.jpg   Wheel pitting on 08 ISF (with solution!)-img_0722.jpg   Wheel pitting on 08 ISF (with solution!)-img_0724.jpg   Wheel pitting on 08 ISF (with solution!)-img_0725.jpg   Wheel pitting on 08 ISF (with solution!)-img_0728.jpg
Old 06-25-12, 07:29 PM
lexsane
lexsane's Avatar
nice.. I gotta try that. how long did it take you to do all 4 rims?
Old 06-25-12, 07:45 PM
Jb2009
Jb2009's Avatar
It only took about an hour or two. Take the time to go over them meticulously and every bit of the mystery dust will be taken care off The rears went pretty easy, but the fronts needed 4 applications of the paste to clean up what remained. I applied the gel for about 10 minutes per wheel and then power washed them down. A few areas were touched up what I missed and it was good to go.
Old 06-25-12, 08:22 PM
obby
obby's Avatar
^ link to the product..?
Old 06-25-12, 08:34 PM
Jb2009
Jb2009's Avatar
http://www.autogeek.net/carpro-iron-x-paste-500.html
Old 06-25-12, 08:53 PM
col250
col250's Avatar
Originally Posted by splitfire
Got my car back the dealer say the pitting is cause by acid beside that I had them fix the rattle on the dash.. when I got my car back it had 17 extra miles on it the tech must be taking it easy on those 17 miles cause gas was way lower!!!!
I took my is250 to the dealer for some issues and they drove it 26miles, wasted 1/4 of my gas and used my e-pass.
Old 06-26-12, 09:43 AM
OneSiCkF
OneSiCkF's Avatar
Anybody had any luck getting the dealer to refinish their wheels in socal? I've only read about less than a handful of stories where the members were able to get their wheels refinished under warranty but dont remember if they were in socal.
Old 06-26-12, 09:45 AM
Evil Teo
Evil Teo's Avatar
I would remove the wheels and tape the wheel weights as mention as a note on the product page. Don't spray on the brake calipers. good to know this works!
Old 06-26-12, 09:47 AM
spddemon
spddemon's Avatar
After you did the wheel clean up, do you feel that either paste or spray would do the job on there own? Do you prefer one over the other?
Old 06-26-12, 10:16 AM
IsFast3r
IsFast3r's Avatar
This thread has scared me just a bit... cleaned the rims the other day and got the same problem with brake dust a little caked in. Used some mother's wheel cleaner and it got most of it out with a toothbrush too.. Is that going to be bad for the rim?
Old 06-26-12, 10:34 AM
cremaster
cremaster's Avatar
those photos above look like my fronts. the previous owner obviously didn't take too good care of the car. i'm ordering this product as well, as nothing else has helped to remove the pitting.
Old 06-26-12, 12:37 PM
iH8RICERZ
iH8RICERZ's Avatar
Interesting read... didn't know this was referred to as "pitting". My wheels have a bad case of it so its time to look into this product or others that are on the market. I remember in a different thread people recommended using the SONAX wheel cleaner... does this stuff work at all?
Quick Reply: Wheel pitting on 08 ISF (with solution!)
