Electric Exhaust Cutouts
Hello all, this is my first post in this forum and I'm needing a little help. I'm seriously thinking of installing two electric cutouts on my stock F exhaust. I love the way it sounds and it's just the right decibel for me. So I'm not looking to replace the stock exhaust but would like to see some performance gains with the exhaust opened up. My research didn't come up with anything regarding any performance gains and reliablility of the cutouts. Are there any F owners who have these installed? If so, which ones did you use and where should they be installed? The youtube vid gave me an idea but am still hesitant. Your opinions would be greatly appreciated.
__________________
2008 Matador Red F (W/E ride) AFE Dry filter, Yellow HID Fogs
2003 Chevy S-10 p/u (DD)
__________________
Where would you add them, right before the mufflers? Or somewhere up further?
At first I was "ehhh" to the idea.. Then I checked out the muffler delete videos on youtube.. sounds pretty good and wireless cut-outs are $200. Makes me kinda like the idea now.
Do you think there is any negative side effects, like hurting the integrity of the system by welding in a random little off-shoot pipe?
I am in the same boat. Where I was going to put them is right after the first set of cats after the secondary o2 sensors. From what I can tell it can be done but you need a good muffler shop. Also if you look at where I was going to put them (hard to explain this) there was a little clearance to put two little pipes coming out the sides of the car just for added kick.
I've been considering doing this same thing myself since I want a quiet exhaust for every day driving, but then I want to be able to open it up for performance when needed/wanted. I am going to be getting headers, and then I was thinking about putting the cut-outs immediately after the secondary O2 sensors and then also upgrading the stock cats to the RT High Flow. So it would go Headers->secondary O2 sensors->electric cutouts->secondary cats (RT high flow)->stock exhaust the rest of the way back.
This should cost about $350 for the pair of electric cutouts + $450 for the pair of HF cats + probably $150 to install everything = $950 total. So it would cost about 1/2 as much as an entire aftermaket exhaust with HF cats, and it would be nice and quiet for every day driving. And I should get slightly improved performance even with the cutouts closed because of the high flow cats, and then maximum performance once I open them up.
And you guys are saying that it will take time for the ECU to adjust to something like that, but then how do you explain people who get immediate gains from an exhaust or header swap? I've seen cases where a dyno was done immediately before and then immediate after and the gains were there right away.
[QUOTE=7No;6447577]You're going to drive around in NJ with an open exhaust?!
I believe that it would be at stock decibel levels when the cutouts are closed.
__________________
__________________
Is it possible to place these cutouts right after the first set of O2 sensors or before the 1st set of cats?
The gains are eh right off. I have a full exhaust and watched the power grow every drive cycle on the dyno. It literally took 5 full drive cycles for the car to get to the gains that everyone is advertising for the exhaust and the headers. If you want power and stock sound buy headers and dont touch your mid pipes or rear section or buy headers and just a rear section... Obviously there your cars but were driving a 70,000 dollar sports car with a very sophisticated engine management and cutting up your very expensive factory exhaust for some noise that isnt going to get great power gains doesn't make sense to me. Again do what you want with your car just my two cents after spending quite a bit of money on my exhaust with a fair amount of dyno time...
If you do the cut outs be 100% ready to admit the fact that its purely for noise and 1/4 or less the power of a full exhaust with 1000 miles on it. I would bet money its sluggish off the line with 0 back pressure and a rich/lean ecu tune trying to figure out wtf you just did every time you touch the switch. In my personal opinion its not for our cars, Leave it to mustangs and civics we are in a different class with the ISF.
