Mark Levinson Radio not responding!
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Hello,
I have an 08 with Mark Levinson and during the past few weeks the volume on the radio has been cutting off and the radio becomes unresponsive. The volume control will not operate, the volume numbers do not show on the screen, the radio will not turnoff. I did the "navigation hack" ~1 year ago and have not had any problems until now.
-Has anyone had a similar problem?
-Any idea of what maybe causing the problem?
-Should i undo the "navigation hack" prior to bring to the deal for warranty service?
Your help will be greatly appreciated.
Absolutely undo the hack before taking it to dealer but that's what I'd do. I wouldn't even bother with fixing it yourself since there's a chance you may just make it worse and often times, if they suspect you've tampered with it yourself, they won't warranty it. Just put it back to normal, see if it still does it, and if it does, take it in. Hope you get it all worked out!
Makster
08-07-22 02:33 PM
DrDave1
04-03-18 03:48 AM
