Lexus IS-F Launch Control
Reading Road and Track Mag I noticed they did some kind of launch control and got a 0-60 4.2 and 4.4 on different tests. Now I assume Lexus did not use that type of technique to achieve a 0-60 time and gets a 4.6. However reading the way the launched the car I still don't get how they did it, if someone has tried this please let me know.
Lexus Connoisseur
Theres no launch control on the IS F. All they did was fully disable TRAC (Trac OFF and VSC OFF) by holding the TRAC OFF button for 3 seconds and put it in Sport Mode. Then from that point they did torque breaking to the stall point of the torque converter. I don't recall what RPM it is.
Ask the guys here that drag race. They will knowthe best conditions for launch. IIRC they rev to 800 or 1100 rmp. Anything more just becomes a smokie mess of wheel spin.
Lexus Connoisseur
Caymandive is a good person to chime on this. He's achieved the fastest N/A times for an IS F to date.
As for launching properly, its also best to deflate the rear tires and keep your trunk empty. Its doable...you just have to find a balance. If you have a 2010 or 2011, you are at an advantage with the factory Torsen LSD.
Here's CrazyMPG, Joe Z (when he still had the IS350) and an 08 ISF with no moonroof that I was evaluating at the time at Auto Club Dragway 3 years ago already (6/6/08). The track temp was near 100 that day so all our times were not that great:
11 Second Club
Published acceleration numbers should be taken with a grain of salt. Really depends on the conditions, mods (if any), weight, wind direction and track prep. It's a balance you have to play around with.
Bump. How does turning traction control and other things off affect launch speeds? Isn't all power going to the wheel with them on or off? Wouldnt turning htem off make the car more likely to do a Corvette WHOOPS I CRASHED AT 30MPH
according to an online calculator, using my time slips from the track, my 0-60 is 3.75 seconds. I have all traction and stability off, car in regular (non-sport) mode, and roll out from the light. This year I will have R comps and plan on building RPMs before launching.
peload the transmission by left foot on the brake and rev your launch with your right foot. many factors in this... your tires, climate, temperature etc, so you could have mixed results launching at 4,000 compared to someone else depending on these factors and more.
I don’t think you can launch that high. We have a 2000 RPM stall, so your limited to 2K I think. I’m not sure how stall is measured.
Tech Info Resource
No one has cut a quicker 60 foot with the TC stalled. All fastest runs have been with mashing the gas from idle. The gearbox won't tolerate much time at stall speed either. The service manual is very clear that a stall test will do great harm if you are imprudent.
