Swapping front left and right tires
Received 1,063 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
You are correct sir. I only had them on my car 20 miles, when they came off.. Never read the sidewall.. LoL
They are indeed marked "Outside", but they have NO directional indicators on them... So theoratically they could be swapped Left to Right ON or OFF the rims, but that would be pointless..
The Continenal Extreme Contact & Yokohama Advan Sports tires are just like that too.
Marked for "Outside", but not direction specific.
Joe Z
Happy Father's Day !!
^^^^Performance tires would have either (outside) marked on the sidewall - Asymmetric. Or (arrows) on the sidewall indicating the direction they should roll - Directional. IOW, on an Asymmetric there is only one sidewall that will face outside. On a Directional tire, either sidewall can face out. Most non-performance tires are Symmetric where the tread is the same side to side and can run any way they are mounted.
Lou
Lou
Lou,
You are correct sir. I only had them on my car 20 miles, when they came off.. Never read the sidewall.. LoL![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Joe Z![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Joe Z
ok, someone can correct me, but i think it's either directional OR asymmetric (inside / outside). i am not sure if there are regular tires out there that are both. ps2 are asymmetric, there is no direction, same with bridgestone from factory on isf. my old perelli pzero nero is also asymmetric, no direction. my toyo t1r on the gs350 are directional, and they aren't asymmetric (there is no inside / outside) so i flip them left/right
Aren't the PS2s NON directional, even though they specify an outside? How bad would it be to swap them then? My dealer says stock toe is what they require, yet STILL my front tires wore out in 15k, rear have 28k and still going strong. I'm getting new rims soon and am terribly tempted to swap front from right to left (dismounting) to SAVE the terrible inside wear. I don't ever track this car, and this inside wear seems absurd, no?
https://www.clublexus.com/forums/the...-the-wear.html
Look at Post No. 3.
Lou
The same inner thread will still be wearing on the "Inside" of the tires..
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Joe Z
Lou
Lou
Below I attached a Symmetrical Directional Performance Tire.
The Nitto NT555 - EXTREME ZR is marked Left on one side & Right on the other..
With Arrows to show rolling direction.
This tire would make a good candidate for dis-mounting and re-mounting from side to side..
![](https://www.tirebuyer.com/tirepreviews/nitto_nt555_detail_386x386.jpg)
I have owned these tires on MY 2001 IS300 and I did actually do just that, to have them last longer..
![](https://www.clublexus.com/gallery/data/2/medium/Tourmalines_Installed_002.jpg)
But, not sure how many owners would put these on their IS-F..
Joe Z
No, I'm saying move the right tire to the left side of the car, keep it facing the same direction, by undermining the term "outside" ? Sounds like a bad idea from Michelin's perspective, but they don't have to buy new tires every 10k miles for non aggressive driving? People don't follow up on this stuff, but if we all do, perhaps Lexus will allow a less aggressive "stock setting" up front for customers who don't intend to track?
i am not sure if it's they don't complain or they don't have uneven wear. my m3 is my daily driver, i only have fun occasionally, and my tires don't last for more than 11-12k. inside also wear our quite a bit faster than outside. on my last tire change, inside was completely bald already, outside still had plenty of tread
Lexus Connoisseur
melbitoast
IS F (2008-2014)
15
01-26-15 07:39 AM
