upgrading to MY11 power steering ECU?
I have read in car mags that MY11 F's have upgraded power steering with better feedback. Anyone know if it is a simple ECU upgrade or are there mechanical parts required along with new ECU? and does the improvement justify the hassle?
Lexus Connoisseur
The changes to the 11 IS F suspension includes revised spring rates, revised shock valving and bushings, redesigned front spindles, etc. It's a total package along with the revised power steering characteristics. You are better off getting an 11.
And yes, as I mentioned previously it is a huge difference and it is a very good change.
Car & Driver
A Thorough Revamp
Still, the IS F had serious potential; its 416-hp V-8 left no doubt about that. But its ride and handling simply didn’t deliver. It would hobbyhorse down uneven pavement and batter occupants in a straight line but roll excessively in corners. For 2011, Lexus addressed these concerns in a big way, changing or retuning every major suspension component. There are softer front springs, stiffer rear springs, larger-diameter anti-roll bars front and rear, stiffer bushings on the rear subframe and rear anti-roll bar, and a new steering knuckle and front lower control arms for reduced unsprung mass. Oh, and the rear camber is tweaked as well. The honking V-8 and the eight-speed automatic carry over unchanged, but a Torsen limited-slip replaces the previously open differential. Engineers also retuned the electric power steering, injecting a dose of much-needed feel.
http://www.caranddriver.com/reviews/...take_road_test
A Thorough Revamp
KiPod
06-12-10 08:47 PM
Lvangundy
11-16-02 12:53 AM
