My Plight
Ah ok, I just figured it might be worth a try since you said it seemed to be coming from the middle of the car.
Riddle me this. DTC P2241 and P2255. These are error codes read through the OBDII port. They came up as Bank 2 Sensor 1 voltage issues. I think this is the front sensor? I have the PPE microprocessor in now... no codes came up for the rear sensors, just these 2 for "bank 2 sensor 1". This is the o2 sensor that I had to extend myself because it would not reach. Anything to do with that maybe? I used copper wire to solder onto the stainless wire in the sensor....
Tech Info Resource
Solder a wiring harness? Hmmm. It would never pass FAA inspection...
More than likely your extension is the root cause of your issue. O2 sensor currents are in microamps, so even a small fault in the extension could cause major issues with the O2 sensor.
Meraki Autoworks
CL Vendor Products for GS-F
04-19-18 03:08 PM
Meraki Autoworks
CL Vendor Products for RC-F
04-19-18 03:07 PM
Meraki Autoworks
CL Vendor Products for IS-F
04-19-18 03:06 PM
GrantReid
Performance & Maintenance
10-11-17 11:44 AM
