Oil Weights
Oil Weights
This is not a specific IS-F question, but I figured more people are interested so this is why I am not sending a PM to lobux
I'm thinking about switching from Castrol to Motul 10w60 in the BMW. However all the literature I've read states the Motul is for bike engines, not car engines. I am trying to find other standards or specs, but as usual the only stuff I can really find is the Mercedes 722 specs
Tech Info Resource
BMW is pretty secretive about their oil specs. They just tell you to run the European Castrol synthetic because it's a group IV oil (really good stuff). No idea if Motul meets (or exceeds) BMW's spec.
There are LOTS of Internet forums with long discussions about BMW and VW engine oil selection.
Castrol TWS 10W30 oil is very old technology - I believe it is Licensed /rated SJ and recommended exclusively for the "M" line.
SJ/ GF4 is 3 ratings ago......SL, SM, and we are now on SN/ GF5.
Motul is not just for the biking set. They make terrific engine oil, just hard to find a distributor. I believe their 10W60 is meant for a 4 stroke motors only....but they make good Synthetic 5W30's if you can find them in your area.
Tech Info Resource
From here. They give you two choices. Regular BMWs can run any SM oil. It never ceases to amaze me how they like the heavy weight oils that take so long to get to temperature.
By the same token, Castrol SRF brake fluid is also very old technology and still found in some of the fastest cars.
The following is the only recommended and approved synthetic oil for BMW M (Motorsport) vehicles in the US market with gasoline engines, at the present time.
BMW Long-life rating LL-01 Synthetic Oils for BMW M vehicles equipped with S54, S62, S65 or S85 engines:
Castrol TWS Motorsport SAE 10W-60 Synthetic Engine Oil
Castrol Formula RS SAE 10W-60 Synthetic Engine Oil (BMW part number 07 51 0 009 420)
Tech Info Resource
All fair and good, but I'd never run a racing oil on the street. It's really bad idea for anyone who isn't competing.
If you're really concerned about it, just send it to Blackstone and have it analyzed, and watch the iron content in the results.
Also read toward the bottom of the page.It tells you which oils have real PROTECtion..Street or not.
Tech Info Resource
But you don't need to believe me. Ask Blackstone what oil they use - they see everything across a cornucopia of oils in the broadest of applications. I think you'll be shocked at what they tell you.
Tech Info Resource
Fair enough. I built my first engine in 1973 after watching my dad who has more years than both of us combined. What next?
Just stick with what BMW Suggests, it's not like you can't find the specified oil. I only use BMW approved oils in my bimmer unless I am topping off and is out of the recommended stuff. If you want to save a few bucks, PM me for info as to where to get your Oil from a BMW dealer at a discount.
