Rear view mirror is loose
Old 07-19-11, 08:12 AM
IS350atWOT
IS350atWOT's Avatar
Default Rear view mirror is loose
My rear view mirror is loose. I was wondering if there was a screw behind the plastic molding piece that I could tighten. It's still under warranty, but if it's something I could do in a couple of minutes, I'd rather do it myself.
Old 07-19-11, 09:11 AM
ohiois350
ohiois350's Avatar
yeah there is crew behind the base in the square box where is attach to the windshield, you remove that plastic cover and tight the screw, good luck
Old 07-19-11, 09:59 AM
CaptAwsm
CaptAwsm's Avatar
I read somewhere that it was a problem they fixed under warranty because of that issue. Does the dealer just tighten it up or is there something else they do?
Old 07-19-11, 10:02 AM
Steve727
Steve727's Avatar
Do u mean the rear view mirror is loose from the windshield??
Old 07-19-11, 10:07 AM
ShadowISF
ShadowISF's Avatar
https://www.clublexus.com/forums/is-...ew-mirror.html
I'm not sure if that's what the OP is talking about though.
Old 07-19-11, 10:19 AM
UCrazyKid
UCrazyKid's Avatar
OP has 2010 car, it should already have updated rear view.
Old 07-19-11, 11:14 AM
IS350atWOT
IS350atWOT's Avatar
No, I think it's just loose from the plate that attaches to the windshield.
Right, I have a 2010 so I think it's already got the revised mirror.
Thanks. I kind of figured it was a screw loose. Probably because the F rides rough, the screw has come loose over time. I'll check it out.
raytseng
RX - 3rd Gen (2010-2015)
05-30-17 09:52 AM
tff
09-16-16 04:42 AM
glostix
ES - 5th Gen (2007-2012)
03-25-16 09:54 AM
SlickRSM
05-06-12 10:59 AM
caymandive
05-30-07 01:46 PM
Quick Reply: Rear view mirror is loose
