ppe headers
i installed the headers myself. personally i only marked one end of the steering shaft as it went into the steering rack. then i took it off. now i never touched the steering during install, and when i put it back on, i lined up the marks and tightened up the bolts. however, i dont see how this part can be messed up because it shouldnt matter what orientation of the shaft as long as you can tighten the bolts back up. if you were to offset the splines a little, it would immediately be noticable when you drive, and the steering wheel is off to one side or the other by a little bit when the car is going straight. then you would just have to un bolt it again, slide it up, turn it whichever way by 1 spline to make it straight, then tighten it back up again. there is play in the wheel side connection but you cant exactly turn the wheel turning it with your hand from below. it just goes left or right ever so slightly. but the shaft is designed to make full rotations, so its not going to matter, and if the steering is off, its an easy fix... 2 12mm bolts, loosen, slide up, rotate, slide down, tighten, done.
i'll be taking my car apart again to replace a front air fuel sensor, and i have to remove the steering shaft and drop the subframe and engine to do so, so i will confirm by about wednesday or thursday when my new sensor arrives.
Mine did but because I was welding cats on they were able to make.it work. Also I believe I'm the only one that has had problems whether it be fitment or mechanical error but I have to trust the mechanic he is.a Lexus tech that opened up his.own.shop and.dos.a lot of power.and.exhaust upgrades. And I have yet to receive a call back from ppe
The steering.g is perfect it faces straight when driving straight I will say the new sound of the headers and the joez together OS perfect. I have to take the car back to them because on hard exploration there is a weird vibrating noise so I need to see if the steering.g shaft is hitting the header so I guess this will be more money. Between the fitment problem and the a/f sensors it cost a lot more to install then the price of the headers . I'm hoping the noise I hear is just a heat shield vibrating .
i'm about to under go this too, can't seem to find anyone around here who will give me a price less than 900 bucks. i'm prolly going to have a speed shop that specializes in toyotas do it. Also they might be able to get it in this weekend, if they do, i'll tell you how it goes since they are doing the PPE / Joe Z combo.
