which one first?
which one first?
i was debating between ppe headers or iss forged exhaust. which stock system is most restrictive? and im guessing running both these would make the car extremely loud right? thanks in advance for the help
I would get the headers if it were me as they are the biggest pain but from what I have read are well worth it. It really depends as the exhaust sounds nice but performance wise, I feel there is more to gain with the headers. Just my opinion and preference between the two if you are for sure going to do both. If you may only do one, the exhaust would be my choice.
I could be wrong, but iirc the headers yield 40whp and the exhaust 19whp?
I vote headers. In your case.
And if you're planning to eventually have both one day, I'd consider the Joe-Z instead of the ISS.
If you plan on ONLY going exhaust, ISS.
Good luck with your decision!
thanks for everyones input. i cant say for sure. im sure everyone knows how it goes. eventually you want to add more. but at the moment i care more about performance then sound. i been searching alot and i see alot of posts with header install "problems' like steering wheel shafts and relocating the dip stick. will these things affect the car? hey miik. why should i go joez with headers?
It is all personal preference. But in my opinion, the iss & header exhaust sounds too loud. Keep in mind that I've gotten 7(yes seven) exhaust tickets in the last 3 years. From all the sound clips, you here some kind if rasp. I hate rasp.
But I prefer the iss if not paired with headers bc it sounds just right.
The Joe-Z when paired with headers sounds better then hearing your child laugh for the first time. Only thing I can compare to is losing my virginity to a women 12 years older then me.
i heard this exhaust with no headers. blew my mind. i think thats what the isf should've sounded like stock. but i was thinking the headers and iss would be too loud. so i wanted to know if i had to choose one. which should i go with? power over sound for me.
i dont want to start a arguement either. im sure the sikky headers are great. but i prefer the ppe for workmanship. 5 or so hp would fluctuate run to run anyway. thank you to all.
You will not gain 40whp with headers and the stock exhaust, but you will feel more of a gain from just an aftermarket header than just an aftermarket exhaust.
If you are eventually going to go headers and exhaust, I would go with the headers first.
As far as noise, with normal driving, the car is slightly louder, more sports sedan like..similar to a stock V8 audi S4..the stock ISF was more quiet than a stock S4 for reference. At WOT, the car has a mean deep scream/roar...2/3 of the noise increase is probably from the KN (kinda roaring and sucking) 1/3 header (more engine roar) but the sound note is synergistically mean.
With the KN alone, i felt some torque loss down low, had to rev to mid twos before feeling the pull. With the headers on as well, the pull from idle on is stronger than stock, easily compensates for the KN. The neck snap effect between 6000-6800 is great. Just shift to cruise at 6000 and then WOT it, man that is fun. Passengers feel it even more.
Had an experienced speed shop install it, this was the first ISF for them. The install was straightforward.....7hr..may be faster for places on the second or third install.
Will add an exhaust but don't if I want the car much louder than stock. Headers plus exhaust combos will be a lot louder than either one alone.
