Air con problem on isf
Hi all,
The air is not cold on the driver side while the passenger side is normal. The temp is same for both side. Any idea on what might be the problem? It was fine before
The discrepancy is very big when the car just started, and then the driver side gets colder, but still not as cold as the passenger side.
Tech Info Resource
Fine before what? It sounds like a very unusual failure.
Your system is more than likely undercharged. Have someone recover your system and see how much refrigerant is in it. You probably have a small leak at the condenser. I see it all the time. The only other cause would be a blend door actuator that has failed on the driver's side. Not too common.
Joncash730
07-01-24 02:59 PM
Blueshark
ES - 5th Gen (2007-2012)
03-20-16 03:14 PM
