Isf nos kit
I doubt anyone would really know, unless you run the same kit & jetting as a current or previous member that had it working.
Depending on the fuel used the only way to jet is with a wideband installed or on a dyno with a wideband and a big set of jets. Trial and error, process of elimination. The companies tech line and an ISF service manual would probably be in order.
~Dv8
~Dv8
Tech Info Resource
Yes. It came from the Factory Service Manual.
btw, anytime you do half the stuff for this car, people think your wrong. guess it's just the nature of the engine? or the car? i've run into a few instances where the shop is like "are you sure"....then the response is afterward 'well i'll be damned". And almost all the info i give places is from searching this board.
NIAautoDesign
CL Vendor Products for IS-F
06-14-18 09:31 AM
Weapon F
IS F (2008-2014)
24
05-08-18 01:10 PM
SlowXIsf
10-09-16 09:14 PM
