Isf nos kit
Old 08-20-11, 01:27 PM
Rider
Rider's Avatar
Default Isf nos kit
Where can I find a nos kit and the pricing? Are there any requirements needed or is the kit just a bolt on
Old 08-20-11, 06:01 PM
7No
7No's Avatar
Search - there are threads on this.
Old 08-21-11, 04:19 AM
darbs242
darbs242's Avatar
There is not a bolt on ISF nitrous kit... you will be taking a v8 efi kit and custom fitting it to your isf, this takes some know how and depending on how nice or rigged the install. It can make a difference in reliability and how finished product looks.
This is my set up... https://www.clublexus.com/forums/is-...-100-shot.html
Old 08-21-11, 01:38 PM
Rider
Rider's Avatar
So all i need is to purchase the kit? Any extras.. In ur post u mentioned somethinf abouy bottle heater and auto opener. What about jets? And i guess the system gets activated upon full throttle
Old 08-21-11, 02:20 PM
darbs242
darbs242's Avatar
You should call a dealer and discus the best option for you. everyones goals are different
Old 08-22-11, 09:52 AM
Rider
Rider's Avatar
What dealer? I thought that they should be left in the dark for warranty issues...
Old 08-22-11, 12:09 PM
darbs242
darbs242's Avatar
Like a nitrous dealer or race shop like JE... not the lexus dealership
Old 09-13-11, 06:55 AM
Rider
Rider's Avatar
Any idea whats the ISFs fuel pressure?
Old 09-13-11, 09:02 AM
Fapout
Fapout's Avatar
Search....
Old 09-13-11, 03:14 PM
Rider
Rider's Avatar
I did try searching. Oh and appreciate the useful post.
Old 09-13-11, 03:33 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,972 Likes on 2,403 Posts
The high pressure side (DI) or the low pressure side (port)?
Old 09-13-11, 05:17 PM
Rider
Rider's Avatar
Both would help, since I am trying to find the right jet setup for the nos kit that I am about to purchase, and my adviser requires this info.
Old 09-13-11, 09:24 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Low pressure is 400 kPa.
High pressure is 4 - 13 MPa depending on what the engine needs.
Old 09-14-11, 09:16 AM
Dv8tion388
Dv8tion388's Avatar
I doubt anyone would really know, unless you run the same kit & jetting as a current or previous member that had it working.
Depending on the fuel used the only way to jet is with a wideband installed or on a dyno with a wideband and a big set of jets. Trial and error, process of elimination. The companies tech line and an ISF service manual would probably be in order.
~Dv8
Old 09-14-11, 09:19 AM
Dv8tion388
Dv8tion388's Avatar
low side 58psi
high pressure 580 - 1885psi
~Dv8
Quick Reply: Isf nos kit
