Synthetic oil Interval
I just bought my 08 IS-F and it has 28k miles on it. I am guessing it has regular oil in it and I was thinking of switching to Synthetic. What is the interval you go after switching to Synthetic? Thanks!
I changed my Mobil 1 0w30 at 2000 and now change my Castrol Edge at 3000. I've had much better experience with Castrol.
You should be fine with 5k intervals if you don't drive like me lol
Ho Motorsports
If you're going to use synthetic oil, the oil should last at least 10,000 miles. All you need to do is change the oil filter at 5k miles and refill the lost oil. Here's proof that 5k oil change interval is irrelevant with synthetic.
https://www.clublexus.com/forums/is-...-uoa-here.html
The major advantage of using synthetic will be the longer oil change interval. Hope this helps.
Terrance
Terrance
So is everyone doing 5k on whatever oil the dealer uses ? Or sooner ?
Tech Info Resource
Tech Info Resource
I'm using the YZZ4 filter. Same as the Tundra.
https://www.clublexus.com/forums/is-...-filter-2.html
I'm using the YZZA4 also.
Lou
