Weird Starting Problem
Thursday I did a major clean wax and polish job on my 2008 F and when I came back Saturday and tried to start it there was just the CLICK CLICK CLICK and it wouldn't start. So I thought maybe I left something on when I waxed it so I recharged the battery.
Came back a some hours later and tried to start it. First of all I noticed the green light in the engine start/stop switch that you push to start it only was amber. The dashboard lit up with all the indicators and the tach did its thing like when it is ready to start but the engine wouldn't even try to crank. Still no green light. My foot was hard on the brake when trying to start. Car is in Park. The headlights were bright indicating to me a good battery charge.
I came back an hour later and still no green light and still no crank. Foot was hard on the brake pedal. Car in Park. Still no green light on the start/stop switch and headlights still bright. I went and got my wife's key and it started right up!!. I turned the car off and went and got my key and it started right up again. By the way I had replaced the battery in both keys just a couple months ago.
Whats going on? I think maybe a computer in the car or in the
Whats going on? Is there a way to reboot the cars computer. Maybe the engine immobilizer is out of sync with the car. How can I reliably start the car if this happens again?
It did sound like the battery of your key, but you said they replaced it a couple months ago. Maybe it quickly drained. I had this problem when I was under A LOT of electrical wires. I had trouble locking/unlocking the car and when I was able to get in, my start/stop button didn't turn green when I have my foot on the brakes. But after several tries, it worked. This probably doesn't have anything to do with your problem, but I had this issue before. Thought I would share.
Glad things are working now.
My car does this anytime my shoes are wet- I have to remove my shoe and depress the brake or the car will not start.
I think there is more to the brake-lock thing than just a switch, it's as if it "feels" your shoe, and moisture etc. will cause this no start condition.
I notice you mentioned massive cleaning job, I bet some substance was on the brake pedal or your shoe.
I've noticed if my key is in the same pocket as my iPhone it won't start. I'm assuming it has something to do with the phones signal blocking the key from sending it's signal to the car.
3 times this has happened (owned car 9 days), and each time sprinklers were running in yard.
Each time car unlocked properly indicating recognition of fob, and fob and phone are never in same pocket.
While my conclusion sounds unlikely the conditions and remedy remain constant for me.
Interesting thing is you think it's normal and haven't taken it in for repairs.
I agree. And interesting that it's not a common problem apparently. It first happened within days of my owning the car, orange light remained on Start button and first I touched the fob to it with no success and then re-pressed the brake several times without success, and finally removed my shoe (it was wet any time this has happened) and the light turned green as soon as my sock or foot touched the pedal.
I set my iphone on top of my keys once while driving and it gave me the key not detected warning, I assumed the same as you, when moved my phone the warning went away.
Tech Info Resource
Or press and hold Disp for three seconds and it will restart while in motion. You can also access this menu while moving by selecting Disp and tapping upper left - lower left three times. I've done this to check speed and GPS satellites while moving.
