Lexus won't fix warped brake rotor on warranty
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
I have a 2008 ISF with 29K miles. Starting around 23K miles the car started to vibrate when I braked above 40 miles/hr, so I took the car into the dealer. They first resurface the rotors, all 4 of them since they found every one has some degrees of unevenness. After around 3K, the car vibrated again, so I took her in and the dealer decided to replaced the front rotors, on warranty. Now, 3K miles later, the front rotors wrapped again, but this time they refused to fix it on warranty. They claimed Lexus refused to pay for them.
I am pretty unhappy, and I wrote to the service director about it. He claimed that Lexus factory service representative was there on the same day as I brought my car in, and he has denied the warranty claim. He also told me that heat warped the brake, so I have to avoid it. I was like, come on, ISF is designed for performance, and its brake rotors can't handle the heat? I never took it to track, only drove around in the bay area, and driven by my wife. It probably sees a life as easy as a Camry driver.
I am looking for advice on how to proceed, since I found his explanation unacceptable. Who should I contact next? The Lexus factory representative? Thanks in advance.
you could write a letter to lexus corporate and see what they say.
However, i think the bigger problem is finding out why your rotors are warpping. They shouldn't be warping anywhere this fast, especially if you don't track your car. Are your brakes installed correctly?
Before anything else, do the next easiest thing. Take it to another dealer. From what I have read in these forums, two dealers will have totally different commitments.
It almost seems like the calipers are dragging or something. I can't see how you could overheat the brakes short of driving around with one foot on the gas and one on the brakes....
x2 on crazymikie; it's unlikely your rotors are actually warped unless you have incomplete pad release. You most likely have uneven pad transfer.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Short answer: cool your brakes before coming to a stop.
Received 1,064 Likes
Right on.... Rotors don't warp.. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
If you post pictures, I bet we will see some nice channel / groove wear patterns.....
Lobuxracer will explain the rest.. (Class in session)
In an nut shell, the Factory Service Rep and/or your service writer doesn't understand whats happening to the Brembo Rotors...
~ Joe Z
~ Joe Z
Did you properly bed in the pads? I have 75k miles on my ISF including 4 track days. I'm on my 2nd set of front rotors, originals on back, and have not had a minute's trouble, noise or vibration.
Bedding procedure I have used: 0-90 WOT, brake hard, repeat 6-8 times as quickly as possible. Then take it to the Texas World Speedway's 2.9 mile closed course and run the heck out of it.
Pat
Pat
Tech Info Resource
I once followed an M3 convertible driver down I-5 for about 25 miles at night. His brakes lights were on the entire time. His brake rotors had a dull red glow. I can't imagine how poor his gas mileage must be.
Thanks! I will try this suggestion, although I think the service history of a Lexus is available to all dealers, so my hope is not high.
How do you cool? If it's just driving locally, and occasional highway, could it be considered overheat? Although it is probably not a good comparison, I am much harder on the 911 Carrera's brakes and did not experience the same problem.
Pat
Pat
I warpped my front rotors on the track with garbage brake pads... oops![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
I had smoked my factory set of pads at 25K with a few track days included and there was two days before another track event. Becuase I couldn't get anything worth having in two days and they were 95 buck I threw a set of Raybestos OEM replacement pads on thinking the stockers did ok on the track. So two days later I drove to the track (5ish hours) and did three 1 hour sessions to get black flagged on my second to last lap of the day because my front brakes were spraking.... I was metal on metal
Not to mention I had been complaining all day like a wet vag because I had lost minimum 200 feet in stopping power from any speed above 60 once they got hot.
I am tuffing out a vibration during braking till the rotors meet minimum width or cracking reaches replacement limits. I have a fresh set waiting for the day... with Carbotech bobcats and xp12/xp10 to rid myself of brake issues.
Probably gonna get some Toyo proxy888's to match the xp series pads on the track... dun dun dun
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
