YZZA4 oil filter explanation from a lexus tech
Tech Info Resource
You might want to check before you commit to using one of those. The Purolator filter I bought had end caps and they didn't allow the filter to go far enough into the housing. The application notes do not include the 2UR-GSE, so if you buy one, be sure to have one you know works on hand too just in case the TRD one doesn't actually fit.
supersonic (05-15-17)
Received 1,063 Likes
The ISF housing is not the same as the ones that use YZZA4 filters..
Till this day, I still use the OEM specific ISF filter... And will continue to do so...
OEM ISF Oil Filter part # 04152-51010
(for those that want the OEM info)
~ Joe Z
nigel821 (04-07-23)
Toyota/Lexus did(?) offer the 04152-38020 for the Land Cruiser/LX 570. It has the same dark color as the IS-F 04152-51010, and came with all the O-rings and drain. I believe it has been superseded to the YZZA4.
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Below is the "Right one".... From 2008 to 2014 that is the only Lexus issued part number..
Joe Z![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Joe Z
Because the issue is with the filter housing....
~ Joe Z
~ Joe Z
Lexus of Riverside (CA) no longer sells the 51010's. Superseded to the YZZA4's, which they sell for just under $12. I respectfully declined and checked virtually next door where the identical filter is $4.
Are the 51010's being discontinued?
Tech Info Resource
I've seen them listed for the RC F as well, so I doubt they're being discontinued. However, UOA shows no evidence of the YZZ4 failing in service, and all my UOAs have shown excellent numbers with the YZZ4 elements. I really doubt there is a difference between the elements.
Cerevo (05-02-23)
lilbluu
06-01-10 03:44 AM
rivera156
Maintenance
12-31-03 01:23 PM
0415251010, 2008, conventional, doesnt, filter, isf, lexus, lexustechcom, number, oil, oul, part, synthetic, tech, yzza4
