ISF Headers for California
I think everyone wishes there were a set of carb legal headers for ANY car in cali. It would definitely make car modding and tuning easier without the worry of a fat ticket for emissions.
There have been in the past. for example Callaway made a set of shorty headers for C-4 and C-5 corvettes, the problem is they produced very little gain and as a result not too many were sold so they wound up discontinuing them. The problem with headers in Ca. is that CARB does not permit the Cat. to be moved or changed.
Really?? I cant tell if there is a bit of sarcasm or if your headers really are carb exempt? Most headers dont have insulation in them because they are high flowing...Correct me if I am wrong, but dont most aftermarket headers contain no catalytic converters?
Tech Info Resource
Really. There are some CARB legal headers out there - it just depends on a lot of factors, mostly how many of them will they sell to recoup the cost of bribing the CARB guys to approve the design.
Preventative, is how I loop through the system. I bought a junk DC Honda header, cut the carb badge off and tacked it to a set of my custom headers on my race car when it was N/A. I then had it all Jet Hot coated black. I got pulled over many times, the couple of times they wanted to see the carb number I would just point to it. They would look at it and move on. Then theres the reflective lables I had professionally printed with real intake carb numbers and a fake brand for my many intakes....
Where theres will, theres a way.
~Dv8
~Dv8
What will you guys do (that have headers and live in California) when California changes the smog laws again and your car has to get the tailpipe/sniffer test?
And does anyone know California emissions laws well? What is the legality of forcing someone to only buy stock manifolds from Toyota at $1200 a piece when I can be completely tailpipe compliant with headers and a good set of carb legal catalytic converters?
After working on many of Toyotas V8s and seeing their manifolds fail at the flange...why am I forced to rebuy a stock manifold with a poorly designed flange that is prone to fail again (whether I am trying to fix an exhaust leak, or fix a P0420-insufficient cat efficiency)?
Right now I have decision to make while replacing my starter; buy headers or not. Like the poster initially said, I don't want to constantly install/remove headers every time I am due for smog.
I would like like to get some intelligent responses instead of the usual 'pay someone some extra money under the table' or 'registering my car some where else'. Anyone?
After working on many of Toyotas V8s and seeing their manifolds fail at the flange...why am I forced to rebuy a stock manifold with a poorly designed flange that is prone to fail again (whether I am trying to fix an exhaust leak, or fix a P0420-insufficient cat efficiency?
What will you guys do (that have headers and live in California) when California changes the smog laws again and your car has to get the tailpipe/sniffer test? And does anyone know California emissions laws well? What is the legality of forcing someone to only buy stock manifolds from Toyota at $1200 a piece when I can be completely tailpipe compliant with headers and a good set of carb legal catalytic converters? After working on many of Toyotas V8s and seeing their manifolds fail at the flange...why am I forced to rebuy a stock manifold with a poorly designed flange that is prone to fail again (whether I am trying to fix an exhaust leak, or fix a P0420-insufficient cat efficiency)? Right now I have decision to make while replacing my starter; buy headers or not. Like the poster initially said, I don't want to constantly install/remove headers every time I am due for smog. I would like like to get some intelligent responses instead of the usual 'pay someone some extra money under the table' or 'registering my car some where else'. Anyone?
Tech Info Resource
FWIW, my Supra was put on the Test Only list without ever failing a single inspection.
