Sway bar
After reading this thread, I dug my F sport from the bottom of my trunk and I tried putting my F sports on last night. The socket for the nut to the link was too shallow plus, there was oxidation. What's a good way to loosen them? WD40 and wait? Plus torque to the spec will be hard under jack stands.
Thanks
https://www.clublexus.com/forums/is-...-2011-isf.html
The F sports are 19mm and the stocks are 17mm.
Thanks
Thanks
You are correct, see the charts I have attached.
BTW, I have the F-Sport Rear bar, had it now for a couple years and I felt an improvement. I didn't change mine with jack stands, I used ramps, they made the job easier.
Lou
From everything I've read the sways are the same. Here's a quote from lobuxracer:
Made here:
Lou
Made here:
Lou
First, the 17mm socket was too shallow, then I got another that was too deep, not enough space for my ratchet. Screw the DIY, I'm going to a shop now. I hope putting an exhaust on is going to be less of a pain.
I called the two local Lexus dealerships yesterday for a quote to install the F Sport rear sway and they both quoted me $257
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I don't care how many 17mm sockets I have to buy, I'll be putting the F on the old rhino ramps and installing the rear sway myself.
I did get a quote of $36 to install my obsidian grille surround though
Thanks for the tip! I'll give it a 3rd try.
I was expecting this to be a 30 minute thing. DIY front rotors and pads and intake were easier thus far.
