ISF emblem removal
I've used the plastic scrapers that you get in the body filler section. Remove the major glue and use goo gone or WD40. Follow up with some Soft Scrub or polishing compound then wax the area. Heat is your friend for getting things loosened up.
The best thing to do is have the holes welded up and pained but it will not be cheap. You can find some small push in clips to pop in the holes and paint them body color but they will look like crap imo.
Mrd916
12-26-13 01:47 PM
MercuryISF
02-03-13 03:33 PM
rizzy
09-07-10 09:25 AM
ilocke
20
11-24-09 01:29 PM
