ISF in the rain (pic)
Received 1,063 Likes
Aweome Rolling shots!!!!!
Correct... Any 2008 to 2010 that does the swap will have a blinking AFS light...
Solution is crack open the dash and black tape the bulb and black tape the area with the AFS image...
Light will still be flashing, but just inside the cluster...
~ Joe Z
looks good... nice action photos...
dunno if this has been discussed but did the AFS give you a warning light or did you just have to disable it? Pretty sure the 2011 headlamp does not have AFS right?
~ Joe Z
Yes, for some silly reason in the US you have to have your headlights on whereas in the rest if the world you can do parking lights + fogs or even highbeams and fogs.
On my isf, u are able to turn on fog when low beam is on, the led in this case. Also if I exit the car every light turns off itself. I thought this is super neat as this I had never had this feature on any other car. This should be in place for any car so ppl would not forget to turn off their head lights. Btw, I changed my fog to hid and also matches color of the led. I usually just have led and fog on. If I have my headlights on the front would be very very bright.
