Done the 60k mile Valve Clearance Inspection yet?
#61
Tech Info Resource
My exhausts were all a go at 0.009", a go at 0.011", and no go at 0.012" save one which was at a very tight 0.012". Not at all worth the hassle of adjusting, especially since I figure if I did a couple of really good WOT runs, or a track weekend, and then measured, they'd all be well inside spec.
#62
Tech Info Resource
Fully validated parts list for anyone who plans to do this. If you are under 100k miles, most of this won't be necessary. If you are over 100k miles, you should replace everything on this list.
11193-38030 = 8 - Gasket Spark Plug Tube
23224-38010 = 2 - Gasket Fuel Pump Spacer
23915-46011 = 2 - Insulator Fuel Pump
23279-74010 = 4 - Gasket Fuel Pressure (Pulsation Damper)
11229-38030 = 2 - Gasket Cylinder Head Cover No. 3 (Valve cover oil filter)
11159-0P010 = 2 - Gasket Camshaft Bearing Cap Oil Hole No. 1
11159-0S010 = 2 - Gasket Camshaft Bearing Cap Oil Hole No. 2
90301-A0029 = 4 - O Ring (Oil Drain Pipe)
11213-38060 = 1 - Gasket Cylinder Head Cover No. 1 RH
11214-38040 = 1 - Gasket Cylinder Head Cover No. 2 LH
90301-09028 = 1 - Oil Tube O-Ring (dipstick tube)
90210-08045 = 6 - Washer, Seal
15678-46020 = 2 - Filter (for the exhaust cam oil control valve)
I also damaged a couple of wiring harness "protectors" in the process. Finding the part numbers for these can be really challenging. Many techs do not bother to replace the broken parts even at the dealership because it's easier just to tape it up and move along.
While you are ordering all that stuff, get the sparkplugs too. They're due at the same interval as the lash inspection on the '08.
The following 10 users liked this post by lobuxracer:
AlOtaBblGm (10-07-20),
bbong (01-27-17),
Bigjon3475 (03-25-18),
GreenJimmy (01-30-17),
ISFPOWER (01-26-17),
and 5 others liked this post.
#65
CL Folding Team Starter
#66
Tech Info Resource
Tech Info Resource
There are a number of these under the hood. Do you mean specifically the big one or some of the other less likely ones? I replaced the big one and the one for the MAF wire on mine. The rest of mine are in good shape, but I have never removed the big one to do the valve lash inspection. That would be dumb. FWIW, the factory procedure is dumb because they say the intake manifold needs to come off and it absolutely does not.
#71
I'm having valve inspection done soon by my friend, I think he'll follow your advice to do the work easier and quicker
#72
Tech Info Resource
Check this post for the three wire harness pieces I replaced besides the big one on top.
https://www.clublexus.com/forums/is-...ml#post9760347
#73
Has anyone else done a valve adjustment on this car? I'm coming up on 60k miles and judging by lobuxracer's findings, i am thinking i can skip the valve adjustment. i know every engine is dofferent but with a larger sample size, it would be easier to judge whether or not it's needed at 60k miles.
#74
http://densoautoparts.com/spark-plug-installation
#75
thank you again!
