Widest Wheel in the Front?
10.5" is too wide for the front. 9" is about as wide as most go, but a couple of people have run 9.5" for their track setup. Of course the most important part is having the right offsets. Are you trying to go for a crazy stretched look or something?
Tech Info Resource
Maybe he's thinking 335's on all four corners. That would be awesome.
Former Sponsor
No idea what the offset is but I have a set of ISSForged wheels that are 20x9 in the front and now added a 15mm spacer to drive for a while cause I want them to be more flush like my rears. I originally didn't want to do any modifications up front but now I don't care I want them to look like my rears. Eventually I plan to order .5in wider lips for my fronts so I will have a 9.5in up front them and it will be a little less than with my 15mm spacer. I will try and find out what my offset is.
I just fit 18x9.5 +22 on the front with 245/40/18. No rolling of the fenders yet and I can turn without anything touching so far.
Lowered about 1.5" on coilovers. They are Hankook R comps as well, so I imagine with regular tires on 19" wheels, you could fit more tread on the normal lower profile.
No pictures yet as I am still tweaking the suspension to see the limits. So far, so good!
Also, offsets are never unknown. You can take your wheel off and measure it with a ruler.
Here is a vague detail of how to do it: https://www.rsracing.com/tech-wheel.html
