ISF VSC and other dash lights on. HELPPPP
so yesterday at night i take the isf for a boot, everything is going great and then i rip it off the lights, as soon as i do the traction starts acting weird and so do the rpms for a few seconds, rights after that the light show started.
check vsc, abs off, traction control off, afs off. all came on at once. i didn't turn anything off.
anyone experience this before?
you install anything recently? VSC gets info from alot of sources. Including the O2 sensor, so if you installed an exhaust for instance, the sensor could be dirty or broken. So if you have any other info on anything done to the car recently, that would help alot
There's quite a few threads about this already but I had it happen to me when the inside of my right front tire wore down to the cords (known issue with the F).
It can also happen apparently if you don't tighten your gas cap enough.
hey. went to a local shop and got it diagnosed, left front speed sensor is not working. going to a shop to see if its the sensor itself or if some of the wiring has gotten loose. hopefully just the wiring!!! ill check the gas cap aswell. thanks guys
Cats
I just gutted my primary cats and my lights came on
Cel
Yea I just came from the muffler shop to see if the O2 sensor were burnt and there not... This sucks answer now we have no first gear... If u find a answer please let me know
dwb
07-22-13 06:15 AM
