Sub and amp install pics into my IS-F
A couple of CL members (VJ),(DCool) and few others have recently contacted me after seeing my sig wanting some info on my sub install. It was pretty straight forward stuff power, signal and ground. Also was going to install VAIS soundlin Q2 that I had purchased in Nov 2010 when I got my F but unfortunately the wiring harness change on 2011IS-F so was unable to install it. So here are some equipment and install pics.
Parts List
JL Audio W6v2 Sub specs
Free Air Resonance (Fs): 28.5 Hz
Electrical “Q” (Qes): 0.497
Mechanical “Q” (Qms): 8.458
Total Speaker “Q” (Qts): 0.469
Equivalent Compliance (Vas): 1.18 cu. ft. / 33.4 liters
Efficiency (1W/1m)**: 83.7 dB SPL
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pt): 600W
Driver Displacement: 0.068 cu. ft. / 1.9 liters
Net Weight: 14.4 lbs. / 6.4 kg
JL Audio 500W mono block amp
Description: Class D Monoblock Subwoofer Amplifier
High-Damping Class D Circuit with discrete control circuitry
On-board Crossover: Fully-variable (40-200 Hz), selectable-slope (12 or 24 dB per octave) LP
Preamp Output: 2-channel (independent active filter, parallel with amp filter or pass through)
Bass EQ: Single-band parametric with variable boost up to +15dB and Remote Bass Option
Infrasonic Filter: Fully-variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On: Permits operation without remote lead
Dual mono speaker output connections: Accept up to 8 AWG wire
+12V and Ground connections: Accept up to 4 AWG wire
Notes: R.I.P.S. Regulated, Intelligent Power Supply, RealSink™ Heat-Management System
Stinger hybrid digital 5 farad cap
5 farad 1000watts
Stinger wiring kit which included 0 guage power and ground wires connectors etc.
JL audio Remote bass control
FAT BOX ported sub-box
Specs [SIZE="4"][:
SINGLE ENCLOSURE, Slot Ported to exact JL Specs
- Dimension: 13" H, 24" W, 11" D
- 0.75 CU.FT. Net Volume, 37.89 HZ. Net Tunning
- ALL 1" Thick Industral MDF
Some pics of parts
![Sub and amp install pics into my IS-F-1290289471089.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/226510d1461116989t-sub-and-amp-install-pics-into-my-is-f-1290289471089.jpg)
![Sub and amp install pics into my IS-F-1290289525276.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/226511d1461116989t-sub-and-amp-install-pics-into-my-is-f-1290289525276.jpg)
![Sub and amp install pics into my IS-F-1290289566915.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/226512d1461116989t-sub-and-amp-install-pics-into-my-is-f-1290289566915.jpg)
![Sub and amp install pics into my IS-F-1290289651454.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/226513d1461116989t-sub-and-amp-install-pics-into-my-is-f-1290289651454.jpg)
Parts List
5 farad 1000watts
Specs [SIZE="4"][:
Some pics of parts
![Sub and amp install pics into my IS-F-1290289807307.jpg](https://www.clublexus.com/forums/attachments/is-f-2008-2014/226514d1461116989t-sub-and-amp-install-pics-into-my-is-f-1290289807307.jpg)
I used two billet aluminum L style brackets nice and clean nothing fancy but it works.
Sorry did take any pics when I installed LOC, grabbed signal coming from factory sub. Going to try taking the signal directly from factory amp see if I can here any difference in sound quality.
I think if has to do with fact it's 1 inch MDF all the way around the box, and W6v2 in that box is just killer could not be happier and sound out put is incredibly rich and clean low bass. Watching moves in car is just fantastic experence now.
