PPE Headers Installed
****Update****
Well Paul got in contact with my installer possibly one bad sensor may have blown a fuse and caused all sensors to code. I will drop by my shop and check the heater fuse. If it continues Paul would send me a new conditioner thanks for the support PPE. I will keep everyone posted.
Thanks
Thanks
I wanted to give everyone an update after Paul and my tech spoke it turns out my o2 sensor is faulty and my shop ordered a new and hopefully will solve the CEL issue I will keep all posted.
Well I am finally back from the shop. Strangely enough I was getting CEL codes on my front drivers side o2 sensor after my tech checked the wiring and sensors apparently the front passenger sensor was faulty instead. After the tech placed the new sensor on the passenger side and a pair of new wiring cables the CEL was gone. Even my tech was bewildered. I did a couple of hard runs to let the headers run hot and no bad codes. I wanted to say thanks to Paul from PPE for his help and of course Gary and Lenworth from Speed Injected I highly recommend them. I am now working on getting a dyno and compare my numbers with other F owners. Happy Motoring
I'm very interested in putting headers on in the near future, but I apologize for the following stupid question to follow: What is and what happens when you get a CEL? Is it just a "check engine" light that comes on and that it? Or is there more too it?
Thanks in advance.
Thanks in advance.
The CEL that most people get from a header installation is damage to the O2 sensors. Apparently they're not easy to remove. The Sikky headers come with a wideband O2... If the headers are installed correctly and the O2 sensors are working you shouldnt have any problems. Im gonna get the headers in the spring as well...
Thanks in advance.
Thanks in advance.
