Minimal gains with Sikky headers
My current mods are Sikky - Joez exhaust and intake. My baseline was 368whp with exhaust and intake. I dynoed my car today after logging almost 500 miles on sikky and the car produced 369whp on the first run and 377 on the second.. so that 9whp gain only ... what can the issue be??
P.S: recently there was engine oil leak.. so i took the car to the installer and he had to remove one of the headers to fix the issue which was done yesterday..
I like the red HSV in your sig too, great Aussie muscle car right there!!!
Based on your results from both the JoeZ exhaust/sikky headers, I think its safe to say that there is either something wrong with your car or the dyno. There is no way you should be consistently disappointing mod after mod.
Which gear?
The correction factor should be SAE not STD. Unfortunately it will be a lower number.
This seems to be all too common an occurrence with our cars. I would put another 500 miles on it personally.
~Dv8
~Dv8
UPDATE on Sikky gains...
Sorry for the multiple threads, but I thought that started a new one with confirmation is better. OK so after my post sikky dyno, I acheived 377whp, which is a 9whp increase from the baseline 368 with joez exhaust and intake in DYNO SHOP #1........ I decided to visit my second dyno shop where I also have a baseline with. My baseline in DYNO SHOP #2 was 371 with Joez exhaust and intake which is normal. The SAD part is that I dynoed 375whp with the addition of SIKKY. So to conclude, the issue is not from the dyno shop, leaving us with either the car or the headers. What do you guys suggest I do? 5whp gain is really frustrating... after spending almost $2000 on the headers and the install. Dyno Below with both baseline and post headers.
I asked you previously if you had scanned the car for any codes, that would be a good start. Maybe you blew a fuse or messed up an 02 sensor. Raise the car on a lift and check for exhaust leaks...
