Enkei RPF1
I think Tire Rack sells these...they should be able to tell you about fitment and correct offsets.
Here is a link with some information
https://www.clublexus.com/forums/is-...-9-5-42-a.html
19's should fit. Stockers are 19" These are what I think I may run. If not Im doing Rotiform BLQ concave 3 piece, 19x9.5f low et, and 20x11r low et with stretched tire. For suspension its going to be custom Bagyard bomber struts front and rear, based off their Audi air struts
Aparantly someone is running a square fitment of 18x9.5 et45 and they clear so you will be fine with an et around 40-45. Only problem I see is the caliper rubbing on the rear of the wheel face. Its not like the IS-F's brakes are huge...
Tech Info Resource
No, SCCAForums ran PF-01s, not RPF-01s. RPF-01s are very unlikely to fit in either 18 or 19. Already did the homework on it.
rome99LS
03-01-12 04:52 PM
