Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
- Lexus: How to Replace Brake Fluid
Step by step instructions for do-it-yourself repairs
Frequency of Brake Fluid Change
Tech Info Resource
![Driving Skid](https://www.clublexus.com/forums/images/smilies/drivingskid.gif)
I ran the first couple days with dot 3 and was noticing brake fade after 30 to 45 minutes. I ran dot 5 and never experienced fade in an hour long session. Either that or I went over the heat range of the brake pads I was running at the time which I guess is possible. A the time I had hawk hp plus on the front.
Does anyone know the bleed sequence on the F? I just changed my rotors and pads this weekend, oem rotors and stop tech pads, but I did not bleed the brakes and I'm at 70k. The fluid looks great and was not low, but if it improves petal feel even better I want to do it asap.
Tech Info Resource
Fluid boiling won't cause fade, it causes complete failure - pedal to the floor, pucker marks in the seat, and if you're lucky you get to pull off gracefully. Pad fade means you press a lot harder and if you pump quickly, you can slow the car (at least I was able to with the F when I cooked my pads before I learned to turn off the stability controls).
Over the years I've used the original DOT 5 silicone fluid (spongy no matter what, but will never damage paint or absorb water), DOT 3 and DOT 4. On the track, there is no difference in feel as long as you've done a good job of bleeding. LCF is specifically designed for low compressibility, but honestly, it's difficult to say it makes a noticeable difference (but at 600F dry boiling, it really doesn't boil even at CMP with four hard braking zones every lap.)
