ECU tuning
#241
You would need to pull the heads and have the DI head ports blocked, and while your at it you may aswell switch in some normal style pistons with a lower CR
#242
To add to this thread, yes we are still waiting on connectors. And from what i know, thrre is almost no timin on this engine, so gains are going to be worth the tune once timing is pulled. Strokergsr(Evan) and the D3 team (Chris and Dave, who did the awesome tig work
) are very well known in houston, have alot of support from many, MANY high end car owners. With that said, this is why i am feeling very safe in leaving my car in their hands and knowing that sooner than later, we will have a tune for the F. Me along with Strokergsr will be tuned, him possibly on juice, me all motor (for now) and after a few thousand miles we will be boostig the F. As stated earlier in the thread a few things are getting made now that WILL be needed, no questions asked. If more is asked from the car you will need these components;
Transmission oil cooler
Engine oil cooler
Trying to figure out how to do the engine oil cooler sisnce it is a cartridge filter. But research will get done. When playing on a back road in austin early sept, i noticed my transmission temp, engine oil temp, and my engine coolant temp were high after only 15 min of hard pushing. So with boost and more power, we will def need a better cooling system. These are getting developed.
Not much of an update but something, dont want you guys to think im out of the pic. Im 100% committed to this.
Engine oil cooler
#243
Engine oil cooler
Engine oil cooler
#244
I know this has been covered in and out before. On my supercharger setup we used the AEM FIC and everyone complained about it what came down to it not working was hood clearance bc of the intake manifold not moving enough air.
but ill put this out there
http://translate.googleusercontent.c...TyDykjxq4crU8w
#245
Im sure once the whole project is done and underway, we will find new bugs that we know nothing off because it hasnt been done. Another thing, that icode, seems to wrk, but we will have to rely on someone overseas for a tune, whereas these guys are located in states. If this did go through and worked fine, who would you go for?
Answer is pretty much there for you.
#247
Tech Info Resource
Be prepared for it to be bricked. Toyota has been notorious for making the JDM and US ECMs fundamentally different. If it works, it will truly be a breakthrough.
#249
#250
Sounds like you're taking the UTEC approach. Taking complete control over injectors etc when certain parameters are hit. Not modifying pulse width and like which tends to **** off the ECU and causes the smart ones to compensate for over time. (which makes for toasted engines)
#251
Quick update:
Patch harness are on their way. Should be arriving this week and hopefully all is done by IFO. Wanna run it and see whats the best numbers i can run on it.
http://instagr.am/p/QybSHNkCSY/
Quick shot of my baby while drving to Dallas.
#252
