Will those tires work?
Old 12-05-11, 02:48 PM
Rider
Rider's Avatar
Default Will those tires work?
I purchased a set of Michelin PS2s 225/40/19 which the stock size few months ago.. which was a mistake. Now its time to change the rears and I want the PSS but the issue is that the 265 wont be available anytime soon, so I will be going with 275/30s on the stock rims. The car is lowered on Eibachs... will there be any rubbing issues??
Old 12-05-11, 03:08 PM
ERDoc74
ERDoc74's Avatar
I'm no expert on this subject, but I believe many people on here are running this size tire on OEM wheels on lowered Fs without issues.
Old 12-05-11, 03:31 PM
ShadowISF
ShadowISF's Avatar
I believe people are on 245 F and 275 R dropped without rubbing.
Old 12-05-11, 04:05 PM
bnizzle87
bnizzle87's Avatar
I've seen 275s on the rear without rubbing. Some are using springs and coilovers and no problem there either.
Old 12-05-11, 06:17 PM
mikefate
mikefate's Avatar
Just roll fenders and go big.
Old 12-05-11, 06:27 PM
Linkseal
Linkseal's Avatar
I am now running 275/30/19 PSS on stock rear wheels, lowered on KW V3, 0.5 finger fender gap, no rubbing and no other issues.
You can run 255/35/19 front and 285/30/19 at rear on stock wheels also without any issue... it has been tested by couple IS-F members before.
Old 12-06-11, 03:59 AM
Rider
Rider's Avatar
The thing is I have 225/40 fronts and I wont change those... SO ill be running 225/40 F and 275/30 R... IS this ok?
Old 12-06-11, 08:53 AM
mugenh22a4
mugenh22a4's Avatar
I had 275/30 Dunlop Direzza DZ101 on Eibachs and stock rims without rubbing...it wasn't even close to rubbing. It could have swallowed a 285/30 easily.
Old 12-06-11, 09:25 AM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
I don't know, but I have a gut feeling you will exacerbate the understeer of the F, with that narrow a tire up front. Also, I have read that the PSS is a better handling tire than the PS2. Construction changes or compound changes or both probably account for this. So, IMHO, I would be worried about using two different models of tires front and rear as well as the smaller cross section up front.
Lou
Old 12-06-11, 10:40 AM
UCrazyKid
UCrazyKid's Avatar
Lou
+1 I foresee a lot of under-steer with that set up.
Old 12-06-11, 11:55 AM
Rider
Rider's Avatar
So I should stick with the 255s ??
Old 12-06-11, 12:02 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,067 Likes on 2,464 Posts
That's probably the last thing I'd do from a performance perspective. If anything I'd leave the rear at 255 and put 255s on the front for a square set up.
Old 12-06-11, 01:12 PM
flowrider
flowrider's Avatar
IMO, Yes!!
Lou
jt321
IS F (2008-2014)
20
07-25-17 08:35 AM
Manh3
IS F (2008-2014)
04-09-17 03:50 PM
rhy
IS F (2008-2014)
19
08-11-11 06:52 AM
black_gs99
Wheels, Tires & Brakes Forum
06-18-10 04:01 PM
byung
IS F (2008-2014)
05-03-10 09:32 AM
Quick Reply: Will those tires work?
