*help check vsc, stuck in "P"
Old 01-10-12, 07:28 PM
boostftw
boostftw's Avatar
Default *help check vsc, stuck in "P"
My friend was helping me uninstall a radar detector that was hardwired to the autodim mirror. After everything was finished the car thru a "check vsc" and now won't shift out of park? I noticed my auto-dim mirror won't turn on but it seems the homelink still functions. Any ideas, I think it might be the fuse but Im not sure which one.
Old 01-10-12, 07:53 PM
boostftw
boostftw's Avatar
*brake lights work, no check engine
Old 01-10-12, 10:15 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,071 Likes on 2,468 Posts
Probably a fuse. If it is the one on the wiring diagram I think it is, it is under the driver's side under a small white cover. Center row, second fuse from the front. There is a diagram inside the cover, the fuse is ECU-IG LH, it's a 10A fuse. If it isn't the fuse, you've got a much bigger problem and I wouldn't want to try and troubleshoot it over the Internet.
Old 01-10-12, 10:45 PM
boostftw
boostftw's Avatar
Lobuxracer,
Thanks for the pointing out that location. I was going crazy trying to track it down. I owe you a lunch if your ever in the Bay Area!
Thanks again
Old 01-11-12, 07:11 AM
StrykarISF
StrykarISF's Avatar
So did that fix it? Updates? Shift out of park now?
Old 01-11-12, 08:09 AM
boostftw
boostftw's Avatar
yes everything is fixed now. That little fuse 10A fuse cause me so much confusion it turned off vsc/trac/ac/power-steering and wouldn't let me shift out of park.
Old 01-11-12, 11:29 AM
DCoolBeans
DCoolBeans's Avatar
another awesome win for lobuxracer Its great to have people like you on these forums
mdsulli
GX - 1st Gen (2003-2009)
10-11-21 10:26 AM
Phil01
RX - 1st Gen (1999-2003)
11-04-18 04:32 PM
Patsum
10-10-13 10:06 PM
mcnelson
08-05-02 05:13 AM
Quick Reply: *help check vsc, stuck in "P"
