oil change
Old 01-17-12, 10:44 AM
frotiss
frotiss's Avatar
Default oil change
Any picture where the oil filter is located
Old 01-17-12, 11:09 AM
staman
staman's Avatar
Dont have a pic cuz my car is in storage but if you get underneath the car you'll see an access panel in the engine undercover...
Old 01-17-12, 11:13 AM
SeanGTS
SeanGTS's Avatar
Yep, maybe 6x10 inches, 4 philips screws.
Old 01-17-12, 11:48 AM
StrykarISF
StrykarISF's Avatar
Heres a pic from when I started on the headers. This is with the entire shield off and no subframe but you get the idea. Like they said above you will see a small black access panel with 10mm black head screw bolts on it, remove those and that small black panel and you will see the oil filter housing in red in the picture below. It is best to use the special socket that fits the housing so you dont booger up the aluminum. Car takes 9.8 quarts of oil with filter. Oh and to reset your light theres a thread on that too! Good luck!
-Mike
Old 01-17-12, 01:23 PM
LBmtb
LBmtb's Avatar
You'll need this special tool to be able to take the filter housing off.
StanleyR
01-06-20 09:49 PM
MicahIS250
11-10-18 08:21 PM
highvoltag
NX - 1st Gen (2015-2021)
17
04-17-18 07:58 PM
Lextranny
03-07-16 02:34 PM
mjdart
IS - 1st Gen (2001-2005)
07-25-01 09:35 PM
Quick Reply: oil change
